What RPM do you guys launch and shift at? - Forums at Modded Mustangs
post #1 of 37 Old January 22nd, 2012, 07:00 PM Thread Starter
95mustangGT/SVT's Avatar
Hey guys I'm curious as to what RPM you guys are launching and shifting your cars at? Please specify if you have a 2v or 4v. I feel like the 4v's shift at a much higher rpm. I am looking for optimal speed, trap, and 1/4 times.
95mustangGT/SVT is offline
post #2 of 37 Old January 22nd, 2012, 07:04 PM
number1gt's Avatar
The launch rpm depends on tires and suspension, but I shift my 2v at 67-6800 do to the cams, otherwise I woldnt go above 6100, the stock redline is 6050
Rock stock
number1gt is offline
post #3 of 37 Old January 22nd, 2012, 07:18 PM
tp88's Avatar
I launch at 2500 with street tires.. I shift at 6200-6300. I have cams but stock valve springs
TURBO FTW
image ru
tp88 is offline
post #4 of 37 Old January 22nd, 2012, 07:20 PM
Launch at 5500 idk what I shift at, just when I feel the cars power start dropping
Do you even lift bro
AED Tune. Cobra jet intake. Rev auto CAI. Lethal X pipe. Eibach Sportlines. 20% Tint.
boduke0220 is offline
post #5 of 37 Old January 22nd, 2012, 07:33 PM
jkolbfleisch's Avatar
Are you looking for suggestions or just what we shift at? My 2v rev limit is set to 7300 RPM with TF heads and upgraded valvtrain and stage 3 Cams. But I have a high-reving setup.
I haven't made it to the track yet with the new engine so I'll find out optimal shift and launch points later.
2001 Mustang GT [645 WHP, 652 WTQ][ON3 70mm Turbo @ 13psi][MMR900][Trick Flow Heads and Intake Manifold][Old Time 11.89@119mph w/ 518whp!]
jkolbfleisch is offline
post #6 of 37 Old January 22nd, 2012, 07:45 PM
JerseyTrueBlue's Avatar
Can you like share a video of this beast revving out please?
True Blue Crew Member #2
315's Crew Member (Dat azz)
255/298 bolt-on's and stuff
JerseyTrueBlue is offline
post #7 of 37 Old January 22nd, 2012, 07:46 PM
BaznastyDave's Avatar
iTrader: 5 reviews
5,500 to to 6,500rpms at launch and shift at about 6,200 N/A, not sure on the spray yet prb launch around 4 to 5K and shift at 6
305/333 WHP/WTQ with CMS Stage II cams
440/552 WHP/WTQ on Nitrous
7.86 N/A
7.15 on Nitrous
BaznastyDave is offline
post #8 of 37 Old January 22nd, 2012, 08:55 PM
skidad62's Avatar
Launch at 5,500 - 6,000 depending on temps with M/T ET Drags with 12 psi shift at 6,400
skidad62 is offline
post #9 of 37 Old January 22nd, 2012, 08:59 PM
iTrader: 5 reviews
^ Oh yeah tires, i run 15" Hoosier QTP's. last time i was out the track it was kinda slick and i was running about 9-10 psi in them, i forgot to mark the tires so i do not know if the rims were spinning inside the tires or not. il be sure to remember to mark em next trip out.
7.86 N/A
7.15 on Nitrous
post #10 of 37 Old January 22nd, 2012, 09:12 PM
p4ndiamond's Avatar
1200 ... i hate having a stock Torque converter lol
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Pi intake Hitech stage 2 cam, Vortech V7-JT Alum drive shaft. Lowering kit x2 ball joints Koni DA, H&R Super race spring LCA "
p4ndiamond is offline
post #11 of 37 Old January 22nd, 2012, 09:13 PM
Mach1dmb!'s Avatar
4V here. I launch at like 2-3k..I'm on stock tires still and I never have any traction. I shift at 6,500
fuck a willing possum
lol seriously.. who the fuck bowls sober and pays for it?
Mach1dmb! is offline
post #12 of 37 Old January 22nd, 2012, 09:15 PM
number1gt's Avatar
Please share videos, that sounds like alot of fun!
Rock stock
post #13 of 37 Old January 22nd, 2012, 09:31 PM
MM's Amazon Man
Wh1t3F1sh's Avatar
My dinky little auto can't launch any higher than 1,500 rpm =(. Otherwise itll break the tires loose and start spinning, or ill never have any traction off the line. If it's hot, 1,500. If it's cold, 1,000. My car blows off the line =/
Amazon Green GT
Unicorn Club Member #2
Wh1t3F1sh is offline
post #14 of 37 Old January 22nd, 2012, 09:44 PM
stal94gt's Avatar
Launch off a 2 step at 4500 rpm on 26x10 slicks. If the track holds more I up the rpms. If it spins I lower it. I shift at 7000 rpms threw a 4v
bone stock from the factory!
stal94gt is offline
post #15 of 37 Old January 22nd, 2012, 11:30 PM Thread Starter
I have stock cams, but full bolt ons like LT's, x, TB, UP, CAI, Tuner, pulleys and a full saleen suspension. What rpm do you guys think I should shift at? I have been shifting at 6,500-6,800 but people have been telling me to shift at 5,500 and lower on here....
post #16 of 37 Old January 22nd, 2012, 11:32 PM
stal94gt's Avatar
A little high there. 6200 is about as high of an rpm I needed to get my best times out of a stock heads/cam/motor 2v
stal94gt is offline
post #17 of 37 Old January 22nd, 2012, 11:43 PM
aarongt2000's Avatar
lies.. redline in mine is 5800. rev limiter is around 61 or 6200.. i launch slipping clutch at like 1500 so its not a clutch dump on slicks like some of these hardcore guys. and i shift to second a little short of redline.. like 5500 ill grab second and wind out 2nd to about redline and powershift to third.. the reason for the change for me is traction.. if i run out 1st ill just spin thru 2nd so i short shift just that little and then use 2nd all the way.. i would do the same out of 3rd cuz traction but i dont need it with stock gears and tune ect. cross the line in 3rd on limiter just one or two hits
aarongt2000 is offline
post #18 of 37 Old January 22nd, 2012, 11:55 PM
US Air Force (retired)
Eagle2000GT's Avatar
I have a GT with a ProCharger. I also have 3.73 gears.
An SVT will run higher rpms that a GT. Launching rpms depend more on tires than anything else. Street tires I have to lauch a 2,000 and bogged down the motor to get my best 60" which was 2.0. Nitto 555Rs need to be really heated up. I wasn't doing it enought at first and just bounced off the rev limiter on launch. But laster, wow. At a 3500 rpm launch I bogged the motor down and got a 1.85 60". With more experiences I'm sure I can do better.
I believe that shifting at 6200 in first is best (redline is 5800). It keeps the motor in the power band better for the lower second gear. I shift at 6,000 for the other gears.
I'm still experimenting. If you ask me this next year you will get a different answer.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370.
USAF 1969-1996: Vietnam veteran. Aircraft maintenance. ICBM Operations. Research & Development.
Eagle2000GT is offline
post #19 of 37 Old January 23rd, 2012, 12:55 AM
Shaun13GT/CS's Avatar
iTrader: 27 reviews
Depends on your power curve. Everyones is different, whether its a NA cammed motor, centri, KB, etc... Reason the 4V shift higher is because the 4V heads are a lot more efficient and make power to 6500rpm. A stock 2V wont maker power past 5500rpm.
My car on my first dyno didnt drop off power, and revved to 6400rpm no problem. So I set my shiftlight at 6300rpm so by the time I shift its probably 6400rpm.
The last time I went to the dyno it stopped making power at like 6100rpm which was weird.
14 Mustang GT M6 - TVS, Kooks Full Exhaust, AED Tune
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
09 Corvette Z06 - 11.7 @ 123.5 (stock)
13 Mustang GT Bolt Ons - 11.58 @ 122.13
03 Mustang GT Vortech - 11.98 @ 118.68
Shaun13GT/CS is offline
post #20 of 37 Old January 23rd, 2012, 12:59 AM
Conditions were different so the readings were different. Every time my car is on a dyno it reads a little different. Those things are not totally accurate.
Human Verification
