2000 Mustang GT 5spd
35.9@16.99
![]() ![]() ![]() iTrader: 17 reviews
fighting a losing battle
I've been fighting with radiator sludge for about 5-6 months. I've flushed the system three times already. How do finally stop the sludge from forming? Every once in awhile I can hear the radiator cap hissing and coolant resi is on the under side of the hood.
Any ideas on what to do?
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html |
12.9 @ 111.44
Sounds like a shitty ass system... Have you replaced your t stat?
![]() l Custom Hotside l TurboSmart l MHS l Hallman l On3 l BBK l Hellion l SCT l Flowmaster l Steeda l AEM l Tial l HPX l Hawk l Trickflow |
35.9@16.99
Yes, thermostat was replaced when I put the ford racing intake manifold on two months ago.
2001 Gt
I would buy a mishmito radiator and never look back. I have owned 2 of them and loved them! The price is unbeatable!
13.7@103
Cabike you looking for stock used cops? PM me.
![]() Bigbore Kooks (parting out 2v motor) N/A 5.3 4v Build
http://www.moddedmustangs.com/forums...ing-build.html |
#6 | |
35.9@16.99
I've read on here that mishimoto radiators are junk for mustangs? I've had one in my wrx and worked well. Even if I buy a new radiator, it'll still be in the motor, Exp tank, hoses etc. Yes, PM'd you.
Tits Magee
4V Swap GT
Id consider unhooking all my radiator stuff, and blowing air through the system
Needing some COP covers for 4V Cobra Did you know if you sound out gullible slowly it rhymes with orange?
Have you got a head gasket issue. My 2v was doing the same thing. Head gasket had a tiny hole,oil was getting by and causing mud to form in my radiator. Funny thing is I had no coolant loss. Well I may have but was imperceptible because I had to flush it every few weeks.
Just pitching ideas
Black and White Crew ![]() Crew Member # 3 centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie |
#9 | |
MM's king of Neon's
404 - car not found
17.81@87
And just another odd one out there, how long have you had the car? I just wonder if the PO might have done something like I don't know, used the wrong coolant type at some point. I believe that can cause some precipitation of sludge like you describe. Or you could just run a huge ass coolant filter like the diesels do.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
Take your radiator out and have it serviced... They take the end tanks off and they clean each row
35.9@16.99
Unsure if I have a HG issue. No smoke from exhaust. Oil is not milky. I'll have to get a pressure test. Has the car about 7-8months? Po lied about everything on car so I'm
Literally clueless on everything service/mile wise. I'll call a radiator shop and see what they think too. Thanks
Priest of the Car Gods
OP - what about the water? You say you've flushed the system multiple times... what sort of water are you putting back in there afterwards?
35.9@16.99
Maybe this is part of the problem:
I bought one thing of dex cool(red) coolant because I had a new bottle at home. When I got home i realized I had a cheap brand at home(green) I drove on distilled water with mix for 5days. 3-6hours of driving like suggested on the bottle. I didn't add water after I added coolant. It's 50/50, I don't add water. Do I?
#14 | |
1999 Mustang GT
^^^ Especially if you're running 50/50. Water transfers heat much more efficiently than antifreeze, it's limitation is it's boiling point. For optimal cooling, you want just enough antifreeze to keep the system from boiling over.
35.9@16.99
Thanks. I'll flush it again this weekend, another t stats and see what happens. Thought I read on here that dex cool is what I should be runnin
to original poster; just an aside. DON'T blow air with a compressor through your radiator or heater core EVER! They can't handle the pressure and you risk blowing out some of the welds or tubes. The pressure test with the right pump up tester is the way to go and usually stays under 25 psi.
35.9@16.99
Not going to lie. I don't know the first thing about pressure testing. A shop charges 15.00 to do it so I'll let them handle that.
I think it's due to running dex cool and mixed with 50/50 green. When I turn the heater on I can smell pancakes/coolant.
2001 Mustang Bullitt 5566
![]() iTrader: 1 reviews
You can not mix dex cool and regular antifreeze because it will cause sludge just like you're describing. (Ask me how I know) I'd drain all of it, pull the top and bottom hoses and flush the radiator, engine block, and everthing cooling related with water. Then run a 50/50 mix of regular green anti-freeze.
![]() True Blue Bullitt 517hp 456tq Vortech | Aftercooler | MHS Blower Cams | MAC LT | Lethal Xpipe | SLP PowerFlo | MM RCA TQA PHB FLSC |
MM's king of Neon's
404 - car not found
17.81@87
That is exactly what I was asking about in my first post. Of course I attributed it to possibly the PO, but if it was you...
Threads Similar to: fighting a losing battle
| Battle of Wills (weight loss battle at work) | Ninjawafers! | The Clubhouse | 4 | October 15th, 2010 08:18 PM |
| ufc style fighting | gooberhead320 | The Clubhouse | 12 | August 3rd, 2009 08:08 PM |
| Best Fighting Games | DOSBoot | Videos | 3 | July 15th, 2008 08:26 PM |
| Fighting sucks! | MustangMally97 | The Clubhouse | 78 | April 30th, 2008 03:59 PM |
| OMG cats fighting outside | 93hatch | The Clubhouse | 4 | April 7th, 2008 01:29 AM |
