Help after using sea foam...
Old June 7th, 2007, 12:08 PM   #1
04GTAMPA's Avatar
2001 Mustang SVT Cobra
04GTAMPA will become famous soon enough
After I started the car to purge the smoke out, now I have a rough idle and very light misfire at idling. What could it be? Thanks guys.
Old June 7th, 2007, 09:03 PM   #2
Ryan Paymaster's Avatar
1996 Ford SVT Cobra
13.36@102
Ryan Paymaster will become famous soon enough
Send a message via ICQ to Ryan Paymaster Send a message via AIM to Ryan Paymaster Send a message via MSN to Ryan Paymaster Send a message via Yahoo to Ryan Paymaster
Re: Help after using sea foam...
Give it time, if it was really carboned up then it's going to run like it's misfiring. How long did you run it? Once you start it up and the initial barrage of white smoke attack, go drive around for a while. I'd say cruise around and get on it once in a while for at least 30 minutes.
The light misfire will go away, or should. Seafoam didn't cause it, hell, if it did it's because there was a problem that was fixing a problem. (Impossibly unlikely I'm sure.)
Old June 7th, 2007, 09:28 PM   #3
Badasstang281's Avatar
Badasstang281 is on a distinguished road
Send a message via MSN to Badasstang281
My car did the same thing. so after 3 days I sea foam it again now it run good
BBK cai P&P 75mmtb P&P plenum BASSANI exhaust MAC x-pipe NO CAT"S ACCEL direct fire coils NGK iridium spark plugs lX7 Eibach pro-kit springs
Old June 7th, 2007, 10:03 PM   #4
cobraetti's Avatar
2001 svt cobra
no way (IRS)
cobraetti is on a distinguished road
how do you guys go about seafoam treatment? or what are the steps?
Build #1249
MM New Edge Crew Member# 6
Old June 7th, 2007, 10:16 PM   #5
04GTAMPA's Avatar
It's been a couple of days now. I'll just sea foam it again. BTW, where did you feed it to? I did it through the IAC fitting, it sucked it right in...
Threads Similar to: Help after using sea foam...
sea foam for my 99 v6 with 49k miles Basics V6 Mustangs 18 November 3rd, 2007 12:59 AM
how to sea foam ?? 96gtponyred 96-98 5 July 22nd, 2007 12:53 PM
