2001 Svt Cobra
01 Svt Cobra help!
I have a 01 cobra with 90k miles, take good care of it, i get a feeling around 1900rpms only of the engine acting like its missing, but never throws a code and seems to only do it when its colder out, and the engine isnt warmed up, i also know when i do a pass it will occasionally flash the check engine light saying multiple cylinders have misfired, could this be a coil on plug problem? any help would be greatly helpful.
12.9 @ 111.44
Check your cops and plugs before you do anything else.
![]() l Custom Hotside l TurboSmart l MHS l Hallman l On3 l BBK l Hellion l SCT l Flowmaster l Steeda l AEM l Tial l HPX l Hawk l Trickflow |
1994 / 2001 Mustang GT
My parent have a e150 with the 5.4l and it would misfire every once and a while especially when it was humid out and it got worse and worse but never threw a check engine light and when it finally did i pulled the info from my scanner and there was a misfire at 1750rpms replaced the two coil packs that went bad and no more problems sounds a lot like your problem and there were only 76,000 miles on it at the time.
![]() 1994 Mustang GT Black-SOLD 2001 Mustang GT Electric Green 2001 Mazda Protege MP3 |
2001 Svt Cobra
i think il just order a set of high performance cops because ive been wanting to do that for awhile and this just helped me descide to do that, i didnt know if it was more serious or not. im sure the 2 step and tune are a bit much for stock cops maybe.
12.9 @ 111.44
2 step probably fucked your injectors and or O2's...
12.41@114
2-step shouldn't be effecting it. When was the last time you checked the plugs on it?? With it having 4-threaded plug holes I would check the trq on them and make sure none are coming loose.
Be sure to do this with the engine ICE COLD.
MM FOBRA CLUB CO-FOUNDER
2001 Svt Cobra
i didnt think a 2 step would be invloved in causing problems, i did plugs about 5k miles ago. do they have a problem sometimes of coming loose? i think with my tune and higher timing, the stock cops are either worn out or cant keep up at higher rpms. You guys probably know alot more than me about this, shes my first dohc motor haha.
12.41@114
Yes mod-motor plugs do have issues with blowing out. Check them.
Also check you chassis ground.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
2003 Mustang GT
A misfire will tend to go away with more RPM. Unless theres just a connection then youll constintley have a misfire. My guess is a bad COP. Very common on these cars. You could wait til the car throws a code, which seems like these fucking cars take forever to throw the CEL on for a misfire, then switch that COP to a different cylinder, wait til the CEL goes on again and see if the code changed to the cylinder you changed it to.
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
MM's king of Neon's
404 - car not found
17.81@87
Check the following things:
Spark plugs. Take them out, get a look at them, check the gap, re-install to proper torque. COP's. Check all connections. Make sure they're installed firmly. Check your stored codes. Typically misfire codes will tell you what cylinder. Focus on those, possibly switch their coils around and see if the problem follows the coils. And FWIW, the "performance" coils are no better than OEM. In fact some have had more problems with the aftermarket ones than the OEM. OEM throws plenty of spark and is tough to beat for reliability.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
2001 Svt Cobra
Ok thanks for all the help guys! Much appreciated! When i get home from college il give it a shot and let you know what i find out, btw where would the chassis ground be?
Plus one. I have had great luck with the oem cops for over 8 years.
Threads Similar to: 01 Svt Cobra help!
| FS:Sweet Silver GT Cobra Brakes/Cobra Seats $$/Bolt-Ons/New stereo/ etc! LOTS OF PICS | Pony Problem | Vehicles For Sale | 17 | February 21st, 2012 09:53 AM |
| which engine for 1500 rwhp 2003 cobra 1999 cobra or 2000 gt | gtjason | New Members Introductions | 14 | February 19th, 2012 09:19 PM |
