cheapest place to order a cobra brake kit? - Page 2
Old January 28th, 2012, 10:28 AM   #21
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old January 29th, 2012, 06:28 AM   #22
April 2012 ROTM
wishIhada5.0's Avatar
2002 GT, True Blue, Stick
wishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the rough
Send a message via AIM to wishIhada5.0
soryr about the jar thing Jazzer...I was posting on my phone and autocorrect decided to step in lol So if I do the cobras with a decent set of pads (say hawks? what do you suggest?) and braided lines with upgraded fluid it should stop like a champ (pending good tires/conditions)?
Jazzer can haz reps for being called Jar
True blue crew founder/member #1
378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer
Old January 29th, 2012, 08:27 AM   #23
Abyssinian of AX
'02 Saleen
19.34@42.259
Your car will still stop in pretty much the same way, but will require less pedal pressure and they will hold up VASTLY better, if/when they get hot. Below, is the last paragraph from Brakes Upgrade thead and a story of OEM brakes and trying to slow down from 100+ MPH
[exerpt from Brakes Upgrade ~ Speeding up slowing down]
Good braking technique: When I was first starting to drive, my father told me a few things about sitting behind the wheel. The first was to aways keep an eye WAY out and up front of me to keep up on changing conditions. Another, was to allow the brakes to cool between uses. To this day, I have never stomped on the brakes and held such pressure for more than a couple seconds (an exception or two!). If I STILL needed to slow down, I would repeat this process ONLY after having completely released them for as long a time as I could get a way with before needing them again. I have only one time, really felt the extent of extreme brake fade. This was about 10 years ago and was in my '85 GT heading down the highway on 100% OEM GT brakes. Long open stretch, no cars, no on-ramps and clear skies for several miles. Opened her up for a bit and got to about 120 MPH for a brief time before deciding to slow down. Well... I was not used to going soo fast, so I put the brakes on and did not slow down the amount I had anticipated, so, after letting them cool a bit, I applied them again. To my complete shock.... there was almost ZERO brakes left The pedal just went WAY down, but was as if I was pushing in the clutch. What I hadn't realized is that the brakes had gotten VERY hot in only a few seconds, due to the very high speed in which I was moving. My instincts kicked in and placed MUCH less pressure on the pedal and allowed some additional cooling between braking to slow down and not have any issues beyond serious fear for a few moments. Of course, this took a MUCH greater distance in which to reduce my speed than I had originally anticipated. Now... had there been another car entering the road or something for which I HAD to stop faster, I would not have been able to and might not be here today and writing the post
My car today would NOT have such an issue in the identical circumstance, as I have brakes that will work WELL beyond what Ford had intended and just may save my life one day
Now, the SN95 brake system was improved over that of the Fox Body that I was driving, but the SN95 can experience this scenario in a similar circumstance.
Jazzer
Old January 29th, 2012, 11:09 AM   #24
April 2012 ROTM
I have had such experience last summer...i had a front caliper hang up on me...pedal went straight to the floor....not fun lol Check your PM's Jaz...
Old January 29th, 2012, 01:26 PM   #25
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
The cobra calipers and pads are the brackets
Rock stock
Old January 29th, 2012, 01:51 PM   #26
April 2012 ROTM
^huh? Lol
Old January 29th, 2012, 03:29 PM   #27
number1gt's Avatar
2002 mustang gt
Your first post you said you wanted calipers brackets rotors and pads, well cobra calipers don't have separate brackets
Rock stock
Old January 29th, 2012, 09:12 PM   #28
jeep45238's Avatar
2003 Mustang GT
jeep45238 is on a distinguished road
1994-04 Mustang SVE 13" Cobra Style Front Brake Kit at LRS - Same Day Shipping!
Does anybody have it cheaper than these folks? Calipers/rotors/pads/stainless steel hoses?
Threads Similar to: cheapest place to order a cobra brake kit?
cheapest place to order exhaust... Truth223 99-04 10 March 25th, 2011 12:47 AM
Cheapest place to order Nitto tires? Mickey 2005 - 2010 27 November 27th, 2009 11:21 AM
Cheapest Place? JVargoPhD Visual 17 May 26th, 2009 02:52 PM
Best place and cheapest place to buy a new rear bumper BDaily V6 Mustangs 5 September 17th, 2008 07:22 AM
Cheapest place to order Mickey Thompson Drag Radial - 275/40/17? tribaltek 2005 - 2010 31 July 23rd, 2008 06:37 PM
