Engine "ticking noise" video linked
I've been lurking around this forum and various other sites for a few years now and have found tons of helpful and useful information that has helped me to fix and do a lot of little things with my stang but this one has me at a loss. I'm pretty much lost when it comes to engine repair so I'm finally breaking down and creating an account.
My mustang started ticking about 1 month ago. This is the noise it makes. This video is with the car warmed up. When the engine is cold it doesn't start ticking till around 2000 RPM. Any suggestions as to what could be wrong would be greatly appreciated! |
Black 2003 Gt 5spd
2hrs@46mph
![]() iTrader: 1 reviews
sounds like a rod knock. sorry man
2001 Gt
I didn't listen to the video because of my location in a library, but it may very well be a lifter that is collapsing. If it only does it when it warms up then you may be loosing oil pressure as the oil thins out and causing the lifter to collapse. Do you have an oil pressure gauage? If so what does it read when the car is warm?
9.2@80 in the 1/8th
Its holding oil pressure, its not bottom end. My guess is either timing chain guides are worn, or its a lifter.
2003 Mustang gt
12.37
![]() iTrader: 3 reviews
stuck lifter or its a spun bearing man and sorry to hear it ive got a motor that im pulling out of mine 130k miles runs good no problems that i know of just putting a built engine in
Current Build: Alum block 30 over all forged 302 stroker kit from eagle P1SC 4" air to water cooler Crower stage 2 cams upgraded springs ported and polished heads stainless steel headers super 44's |
My initial thought was a lifter/lash adjuster but from what I've read it would be happening even when the engine is cold too. The oil pressure thing makes sense but the oil pressure gauge is reading fine so I'm kind of at a loss. Someone also suggested timing chain tensioner so I'm gonna check that out. I'm just praying its not a spun bearing or a pushrod.
9.2@80 in the 1/8th
Modular engine means no pushrods... the cams are right on top of the valves, so no pushrod is needed to open/close them.
2003 Mustang gt
12.37
I hope he meant connecting rod but i doubt its a spun rod just bc i dont see how it could even run for a month and if it was a spun rod rpms would be held down and wicked vibration from the rotating assembly being off balance but just put a boss 302 in it and call it a done deal lol
2003 Gt
slow
looks like you have an excuse to get a built engine
9.2@80 in the 1/8th
It'll run with a spun rod bearing. It will just use oil. It'll run forever if you keep oil in it..
Black 2003 Gt 5spd
2hrs@46mph
yea ive run cars for literally months on end and sometimes even abused em with spun bearings. it gets worse little by little but it'll def run for a long time if its oiled. but good news is, theres always a 5.4l block waiting for a good home in a mustang
11.85 @ 125
![]() ![]() iTrader: 2 reviews
not a spun bearing.... I have heard this a ton of times and I have even had this same issue. It's in the heads. Your not getting enough oil up to the top of the engine and the lifters are collapsing. I have had luck on getting rid of the issue with a simple oil change.
If you problem sound like it is a marble on top of the engine, then its a top end issue. If it sound like a slap, then it is a rod. I would suggest doing an oil change first and then go from there. Just so you know, the Oil pressure gauge in the dash is basically for reference. You need an actual pressure gauge to know for sure. |
2000 Gt
my engine makes the exact sound when it's cold, when its warmed up and has some oil flowing through it the sound stops almost completely, i also have a 65% loss of compression on a leak-down test in cylinder 3, and nothing on a static compression test, i've had a few people suggest it might be a problem with the piston ring, best of luck i'm pulling my motor apart on tuesday.
2000 Gt - full bolt on's 3.73's eibach suspension. 265hp/307tq |
Threads Similar to: Engine "ticking noise" video linked
| Isolated My "Ticking" Problem | supermachone | 99-04 | 14 | November 13th, 2011 07:39 PM |
| is "ticking" common with our 2vs? | lehrskee | 99-04 | 25 | July 17th, 2011 04:21 PM |
| engine makes a "whining" noise | PolishSasquatch | 5.0 Mustangs | 3 | October 8th, 2009 02:16 PM |
| Roush "Off-Road" exhaust installation with pics and video | DiMora | 2005 - 2010 | 18 | May 23rd, 2009 03:59 PM |
| Any Real "RACER" Notice Whats Wrong In Our Video? | CAMN89GT | The Clubhouse | 41 | November 19th, 2007 09:03 AM |
