2000 gt
guessing horsepower based on ET or MPH?
anyone good with this stuff? my gt has a best mph of 91 and a best et of 8.20 (with a 1.8x 60' on that pass, that's the best we could get). that was with a procharger (50 lbs or more with piping, intercooler, head unit, etc...), mach 1 hood with shaker at the time, probably 30 lbs over stock, 5 speed, full exhaust without cats so losing a few lbs there, a 300 lb driver (no not me lol, but i'm at 230). on the dyno i made 413 hp and 450 rwtq. never weighed the car but it was pretty heavy on those passes.
what kinda power does that suggest? or anything besides the actual weight you'd need to know to guesstimate?
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
2003 Mustang GT
Well, Im making 380rwhp SAE Corrected on a Dyno Jet. And Ive trapped a lot of high 89mph to low 91mph on a consistent basis, best of a low 92mph.
But a lot plays in affect. A dyno reading is just a number. Someone could make 400rwhp at high elavation, but lower trap speed vs someone with 350rwhp at sea level. Barometric pressure. The higher the better, since its pressure, the more you can shove into the blower to compress the better. DA, humidity, etc play a big roll. This guy, making 600rwhp only trapping 120mph. Cobras with a 2.7 pulley, intake, and exhaust trap 119-120mph and are a little heavier. His DA is like 6500ft so thats killing him.
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
02 Mustang GT
9.91@133
Wallace Racing HP Calculator For 1/8th Mile
My car traps 101 in the 1/8 running 8psi and weighing about 3550lbs.
2002 GT PI heads Twin 60mm turbos Th400 6.34@114 1/8 9.99@137 1/4 http://i160.photobucket.com/albums/t...t/DSCF5654.jpg http://i160.photobucket.com/albums/t...2gt/IMG060.jpg |
2004 Mustang
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Best i have ran on motor was 87 mph with 285 WHP, best on nitrous was 94 with 385 WHP and a 2.1 60 foot spinning 1st and 2nd
![]() 305/333 WHP/WTQ with CMS Stage II cams 440/552 WHP/WTQ on Spray 7.86 @ 89.1mph, 1.61 60 foot N/A 7.20 @ 98.8MPH 1.55 60 foot on spray Stock Longblock with Cams |
#5 | |
04 mustang gt
7.21 @ 98
91mph doesn't really suggest 400+ rwhp (then again your car seems pretty heavy) but i don't think you can make an accurate guess with a bad sixty foot. at least not in my experience. my mph has always went up with a better sixty foot...i'm sure if you get the 60' down in the 1.5-1.6 range the mph will go up. 380rwhp got me 93mph and then bumping it up to a 150 shot got me 98mph (maybe 420-430rwhp?)...on street wheels with a 1.8 sixty foot it only did 89mph on the 100 shot (380rwhp)
![]() cams + 150 shot |
2000 gt
Ok just wondered
12.73@111.36
I tried that calculator using 8.260 @ 88.43 mph weighing 3600 lbs. It said 290 rwhp. Interesting, but wrong. My car has been on three separate dynos (two dynojets and a mustang dyno) and the range has been 370 to 385 rwhp (no changes to the car). If the calculator is correct then the entire automotive industry has formed a huge conspiracy to defraud us. I'm not a believer in huge conspiracies.
As was mentioned before there are too many variables. But some of the same variable affect dynos as well. That's why there are correction factors and slightly different results. Edit: That was based upon ET. I read futher. For trap speed it said 365.59 rwhp. It obviously expects a better 60' than I have and a lower altitude. I'm at 1000 ft.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. Last edited by Eagle2000GT; January 29th, 2012 at 01:47 PM. |
Hooo Ha Ha
Calculating my hp from ET its says I make 407
![]() 410rwhp 520rwtq @ 12.9 psi |
02 Mustang GT
9.91@133
The calculator shows how much hp the car put down on the ground while making the pass. Spinning, slow shifting, short shifting or shifting way over power band will not have good time slips.
My car 8psi 7.42@101.41 shows 602fwhp with mph. 15psi 6.89@109.03 shows 748fwhp with mph. 18psi 6.34@114.30 shows 862fwhp with mph. This all shows my engine making about 390fwhp n/a and about 312rwhp n/a. It seems to be right using what I know about my setup.
12.73@111.36
And track prep. Test and tune days do not always have the same track prep. I was in line once when a guy a couple of cars up blew an engine. We set almost an hour while they clean the track and re-prepped it. It made a huge difference. The spun a lot the pass before launching at 3000 rpms. That pass the tires gripped and bogged down the motor launching at the same rpms.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
Yes, the calculators are based on physics. Force equals mass x acceleration and all that. If you can hit the times the calculators give, you're looking at a near perfect run.
-Brian ![]() 2004 GT TR3650, MAC Straight Shot CAI, FRPP 70mm, TFS plenum, catted X-pipe, Pypes Violator polished 304SS cat-back, custom tuned by AM/Bama...... 4.10's - coming soon! |
Threads Similar to: guessing horsepower based on ET or MPH?
| just fun on guessing what i could run | JD mustang | Drag | 19 | April 14th, 2011 09:38 PM |
| Anyone here a hp guessing whiz? | DegralDan | 99-04 | 19 | April 25th, 2010 08:25 PM |
| No more guessing | garydahl | 2005 - 2010 | 8 | February 27th, 2010 10:40 PM |
| HP guessing game | mystang0673 | 99-04 | 26 | January 27th, 2010 06:14 AM |
| Guessing game....... | silverstang | 2005 - 2010 | 64 | April 30th, 2009 12:05 AM |
