alu drive shaft on an auto?
Old January 29th, 2012, 02:25 PM   #1
'03 GT
15@98mph :(
Macattac is on a distinguished road
As the title says. Can I change to an alu drive shaft on my A/T GT?
And if yes, does it require alot of work?
Magnaflow Catback | Steeda UDP | UPR CAI | AccuFab 75mm TB+Plenum| 14" rotors with 8 piston calipers | BMR LCA&UCA | Eibach Sportline Springs
Old January 29th, 2012, 02:35 PM   #2
CobraStang161's Avatar
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
CobraStang161 will become famous soon enoughCobraStang161 will become famous soon enough
I have one in my car. It uses 1330 yoked which is nice.
Built 4V Motor with Sullivan Single Plane Intake
Custom 66MM BB TT kit
Borla XR-1 Dumped before rear
Moser built 9" Rear
35 spline WaveTrac Diff with 3.75s
35 spline Moser axles
14PT roll cage and minitubbed
Old January 29th, 2012, 03:35 PM   #3
'03 GT
15@98mph :(
Where can i get that yoke? Am?
Sent from my Autoguide iPad app
Old January 29th, 2012, 03:41 PM   #4
I believe when you order the driveshaft from ford racing it comes 1330 yoked
Moser built 9" Rear
Old January 29th, 2012, 03:58 PM   #5
wiggety wiggety whack!
brokenweasel's Avatar
brokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of light
I have heard you can just take the yoke off your current driveshaft and re-use it. Where are you planning on getting an aluminum driveshaft? I have heard interceptors had them, and most (if not all) of those were auto's, does anyone know if those are direct replacements?
Originally Posted by dr.gonzo? View Post
Monkeys wear spandex with hotdog legs because race car.
Originally Posted by IndianaJoe View Post
yesterday was shorter because of the massive burnout i did, it spun the earth faster.
Old January 29th, 2012, 04:00 PM   #6
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
I've worked on alot of police interceptors and never noticed an aluminum drive shaft
Rock stock
Old January 29th, 2012, 04:13 PM   #7
justAbullitt's Avatar
2001 Bullitt
justAbullitt will become famous soon enough
Yes, I run an frpp on my car, although its a manual. Make sure you buy the correct one for an auto car. The job is easy, make sure you have 12 point shallow sockets. depending on your milage you may also want to replace the tail shaft seal in your trans.
Sent from my phone
Bullitt #4592
Mods list in my garage
Google+
Old January 29th, 2012, 04:36 PM   #8
number1gt's Avatar
2002 mustang gt
Did you notice a difference? And also in vibration noise as well
Rock stock
Old January 29th, 2012, 04:44 PM   #9
I'd like to know for sure, because I'd love to pick one up from a junkyard for cheap.
Wikipedia says this:
"Ford used an aluminum metal matrix composite driveshaft for the 1993–2005 Police Interceptors as a measure to allow safe operation at over 150 mph (241 km/h), but it was more expensive than the regular aluminum driveshafts. Ford reintroduced the 3.55:1 rear axle ratio in the 2006 model year Police Interceptors, and set the speed limiter at 120 mph (193 km/h) to reduce the risk of driveline failure."
Ford Crown Victoria Police Interceptor - Wikipedia, the free encyclopedia
Old January 29th, 2012, 04:51 PM   #10
number1gt's Avatar
2002 mustang gt
The ones I worked on were att least 08s and up, so might be why lol
Rock stock
Old January 29th, 2012, 04:57 PM   #11
'03 GT
15@98mph :(
Where I plan on getting it? New from frpp I guess. Not many interceptors here (readne)...we have volvo, bmw and mercs for 'interceptors'.
Old January 29th, 2012, 08:51 PM   #12
2001 Bullitt
I installed with my 4.10's as a measure to combat any vibrations caused by the gears. No noise and if I did just a drive shaft I doubt I would notice any difference from the factory shaft.
Bullitt #4592
Google+
Old January 29th, 2012, 09:05 PM   #13
number1gt's Avatar
2002 mustang gt
Well less rotating mass is somewhat noticeable
Rock stock
Threads Similar to: alu drive shaft on an auto?
Drive Shaft HOLLYWD69 2005 - 2010 5 December 31st, 2010 07:40 PM
drive shaft shop one piece steel shaft ok for automatic tran mustang fanatic 2005 - 2010 8 September 24th, 2007 01:21 AM
drive shaft scxc15 V6 Mustangs 28 September 6th, 2007 06:20 PM
aluminum drive shaft for an auto??... 99spaded 99-04 0 July 15th, 2007 10:30 PM
drive shaft ? Drgnracin72 99-04 2 April 13th, 2007 10:26 PM
