2001 Mustang GT
9.30 @ 77mph-1/8th mile 2.2 60'
![]() iTrader: 3 reviews
complete engine lifting points
ill be installing the new motor soon as a complete. with intake and throttle body. where do you guys usually put an eylet or bolt to drop the engine in. i now have a load leveler. before with just chains i was going from top bellhousing bolt to alternator bolt hole. but with the new one that method is crushing the wire harness in the rear.
01 GT. 5spd , 03-04 cobra clutch, on its 2nd 4.6l motor 2nd tr3650 too,JLT CAI,UPR o/r x, magnapack catback, predator tuned, H&R ss 10.5" bullitts w/ nt555r DR's
MM's king of Neon's
404 - car not found
17.81@87
The ones I used were the two just above the water pump (or the two timing cover studs near there work as well), and two on the rear of the intake.
Whatever you do, DO NOT attach anything to the rear face of the block/heads. There will not be enough clearance to install the motor, I learned that the hard way.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
2001 Mustang GT
ok thanks...do just re-torque the intake bolts when finished? cuz i thought theree was a torque sequence for the intake manifold
MM's king of Neon's
404 - car not found
17.81@87
That should work. I don't see a reason not to, especially since the outermost are typically the last to torque anyway.
2001 Mustang GT
good point
Threads Similar to: complete engine lifting points
| FS: Complete engine out of 03 GT | Mustang_GTX | 1999 - 2004 Mustang Parts | 1 | December 30th, 2011 04:39 AM |
| Engine lifting question? | stew112 | Modular Mustangs | 6 | January 11th, 2010 04:30 PM |
| lifting engine off of mounts? | 91cobra5.0 | 5.0 Mustangs | 8 | October 31st, 2008 02:23 AM |
| which complete engine would be best | shadow5403 | V6 Mustangs | 6 | January 16th, 2008 09:33 AM |
