2001 Mustang GT
Time for heads and cams, help please!!!
So my car wasn't running right and my mechanic diagnosed that one of the cylinder heads is cracked. So iv'e decided it time to buy some new heads and cams for the car . This car is my dd and i'm not planning on putting a s/c on it so what cams and heads would be the best for my application to give my car that extra power? and about how much would it cost to have heads and cams installed if any of you guys have had it done?
What else is done to the car? Nothing if you want to keep it streetable- get someone that knows what they are doing, maybe some mild cams in it, degreed, a good premium tune and leave it alone.
2000 Mustang GT 5spd
35.9@16.99
![]() ![]() ![]() iTrader: 17 reviews
Trick flow heads/ cams. Tune
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html |
2001 Mustang GT
Right now i have a cai, steeda pullies, flows 44s with o/r x pipe next im goin to get 3.73 gears soon.
04 GT
I like boobs!!!
2000 GT convertible
dunno
TRICK FLOW!!!! 'nuff said
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
![]() ![]() iTrader: 6 reviews
Depends. What you looking to spend? Any power goals?
Look to spend anywhere between 650-1200 depending on the shop.
I like boobs!!!
2000 GT convertible
dunno
fixed it for ya
No. That was for labor, not the cost of the heads n cams.
I like boobs!!!
2000 GT convertible
dunno
Gotcha
2001 Mustang GT
2004 Mustang
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Cheaper way would be some Stock PI heads, ported with some Stage II cams.
![]() 305/333 WHP/WTQ with CMS Stage II cams 440/552 WHP/WTQ on Spray 7.86 @ 89.1mph, 1.61 60 foot N/A 7.20 @ 98.8MPH 1.55 60 foot on spray Stock Longblock with Cams |
Very unlikely the head is cracked. More likely a blown head gasket. Have the actual heads been removed and magnafluxed?
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
Can fill 7 car garage
I have not heard of the PI heads cracking.
Regardless, I have had a set of Patriot Performance Stage 2 heads on my '01 Roush from 18k miles to now 51k miles (odometer reading). Patriot sells their own cams (or at lease did) but I have a set of Houston Performance S292 cams. I have a D1SC @ 11lbs making 502rwhp. |
#15 | |
Nick McKinney, the owner of MHS, does some of the best work and I wouldn't hesitate from buying from him. He knows his shit and won't try and sell you something you don't need. I'd shoot him an email, tell him what you're looking for and he'll get back to you with a recommendation. Modularheadshop PI heads
I like boobs!!!
2000 GT convertible
dunno
I've heard lot of good things about MHS as well, but if you're on a time constraint you might want to look into some off-the-shelf stuff. If you go custom porting and custom grinds on your cams you will be waiting a while.
11.463@121.50
You could give Modular Mustang Racing a call. I'm running a set of their ported PI heads (stage II). It took me about 2 weeks to get a set from them.
They'll sell you cams too. You'll be able to wind the motor out to 6500+ rpms with ported heads and cams!
MM Bracket Racing Crew Member #5 |
#18 | |
2000 MUSTANG GT
if you are just looking for around 300rwhp then you can just find you some stock replacement heads and cams be be around that mark.
2001 bullitt #835
not fast enough
Bullitt #835 4:10s, bassani O/R X, bassani mufflers, Bassani mid-headers, forged/built 2v, trickflow 44 heads, BIG blower cam, v1 vortech intercooled 11# boost 532rwhp/468tq
2001 Mustang GT
we compression tested two of the cylinders and they were well below the cr like the others. the car runs really bad and sounds like its cammed and when u gun it takes a while to get up there. He said it's either a bad head or bad piston. what do u think?
Threads Similar to: Time for heads and cams, help please!!!
| Time for Cams | Chocolame | V6 Mustangs | 14 | May 16th, 2010 09:10 PM |
| Time for some Cams | GOTTORQ | 2005 - 2010 | 60 | February 10th, 2009 10:24 AM |
| Maybe Time For Cams? | Youngin | 2005 - 2010 V6 | 11 | August 27th, 2008 04:15 PM |
| TIME HAS COME!!! NEW HEADS AND CAMS...INPUT PLEASE! | amphibrecon | 99-04 | 25 | June 22nd, 2007 09:31 AM |
