#21 |
ok so with the belt off start the car, rev up no squeak then must be a puley?
#22 |
yes, then you gotta go pulley by pulley to find the problem.
#23 |
Could it possibly be my headunit? or the small pulley attached to it? the weird thing is, after i replaced the pulleys the noise went away until it started raining last night and today we sprayed some belt conditner on the belt and that just made it worce
#24 |
what kind of condition is the belt in? that would be step one to me... look at the ribbed side and see if its dry/glazed and cracking...
2004 Mustang GT 40th Aniv 5spd, Stock for now. 2005 Joe Gibbs Silverado #0396 1986 Monte Carlo SS |
#25 |
The belt is brand new, we put it on last sunday
#26 |
2001 Bullitt
Sounds like the belt is your issue. Just take the blower off an start the car nothing bad will happen. Check all the pulleys for play and noise and throw the old belt on. If it doesn't make noise with the old belt then it's the new belt causing the noise.
Sent from my Autoguide iPhone app
01 DHG Bullitt Stroked, Forged & Blown Built Rear, Viper T56, Suspension, Drag Radials 374.6 rwhp 374.4rwtq @ 4.6L 10psi Now 5.1 and 15psi, no idea on the numbers!! |
#27 |
Was the belt, put a smaller belt on, sounds smooth as new!
#28 |
ok well new belt to tight? when we put the new belt on the tensioner was maxed out ant the tensioner houseing hits on my procharger headunit mounting bracket, anyone else have this issue?
#29 |
12.73@111.36
If the belt squeals when the motor is cold and goes away when its warmed up, its usually a tensioner. Since you changed the tensioner it has to be something else. Are you sure you got all the spacers back in and the supercharger pulley is lined up?
By the way, I ran my car 6 weeks without the head unit when I sent it in to have the seals replaced. Even with superchargers our cars normally operate with a vacuum. The MAF, ECU and injectors are already calibrated to run without boost. It doesn't hurt anything.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
#30 |
12.73@111.36
You have to grind off the belt gaurd on the tensioner. If you don't it will hit the ProCharger bracket.
#31 |
Ohh ok so that will prob fix my issue! cause its wedged againt it now so when i rev up the tensioner cant move, so the belt slids on the crank pulley. hopefull cutting that lip off fix's that issue, now to fix my bypass valve humph car is just problem after problem haha
#32 |
GRRRR!!!! alright so iv replaced the belt twice the tensioner pulley both idler pulleys and i still have the chirp under the hood! IM SO LOST AT THIS POINT!!! we put all the spacers back in the pulleys all lign up, i did notice that my procharger isnt clocked correctly, not sure how to make it right but i dont see that being the cause of my problem?
#33 | ||
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
#34 |
yeah i started the car w/o the belt and the noise is gone, i replaced both idlers the smooth and the groved one and the whole tensioner pulley... i put the smallest belt that we could get on with a pry bar... could the belt be to tight? doesnt sound like the altanator to me
#35 |
Can someone post a pic of how the pulleys should be installed like which direction? and do they need to be torqed down or just bolt them as tight as possible?
#36 |
12.73@111.36
What size belt are you running?
#37 |
107 7/8's Gates # K061073
#38 |
12.73@111.36
Well, I'm pretty much at a loss. I'm running a 108" belt. I've had pulley squeel because of the tensioner being bad. Like you described, a squeeling noise on cold start, then when you spray belt dressing on it, it gets worse. But that was the tensioner. When I watched it, it was bouncing up and down. It should be steady. It should hold the belt tight regardless of rpm.
#39 | |
#40 |
No but i dont have to change my oil 6 days in a row to make it not squeal... thought i was getting belt sliping so tighter belt...
Threads Similar to: Loud Squealing noise from under the hood ekk
| Squealing noise | slvrbullet01 | 99-04 | 16 | September 4th, 2011 07:02 PM |
| Squealing noise | JU$ | 5.0 Mustangs | 18 | March 4th, 2011 06:10 PM |
| Loud squealing from Crankshaft and P0340 Code | Mizah87 | 99-04 | 2 | January 1st, 2011 06:49 PM |
| Squealing noise from cooling fan means what? | zdkel | 96-98 | 1 | November 8th, 2010 07:48 PM |
| Squealing noise under hood | hardhitter | 99-04 | 29 | August 29th, 2008 11:37 PM |
