Loud Squealing noise from under the hood ekk
Hey guys got my new clutch done last night, NIGHTMARE with my long tube BBK headers
![]() so got the car all back together and today i have a new issue, i loud squealing noice comeing from the engine bay, prob a pulle, i replaced the belt last night same issue... any ideas? it gets louder at acceleration also Thanks guys! |
MM's Slowest Member :(
There has been alot of threads like this.
My car does it sometimes while warming up, although stops when it gets warmed up. Sometimes doesnt even do it at all.
Mine does it all the time, very annoying! haha guess ill start with the tensioner and idler pulley and see what happens..?
Did you do the auto adjustment on the pedal after completing the clutch change... And did you replace the TOB?
2004 Mustang GT 40th Aniv 5spd, Stock for now. 2005 Joe Gibbs Silverado #0396 1986 Monte Carlo SS |
How do i do the auto adjust? yes we replaced the TOB and the Piolet barring... sound sounds like up front by the pulleys?
2000 gt
power steering fluid low? check that
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
2000 Mustang GT 5spd
35.9@16.99
![]() ![]() ![]() iTrader: 17 reviews
My ps pump will squeal when it's cold outside. Once car warns up it goes away.
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html |
What brand TOB did you use and did you lube it?
2003 Mustang GT
Take your belt off and spin all pulleys and idlers by hand to see if one is bound up (besides the crank). Also start the car with belt off and see if it still makes the noise. If it doesn't squeal without a belt, then obviously you have a belt/pulley issue.
Sent from my Autoguide iPhone app
![]() '03 GT w/BBK CAI, MAC Pro chamber, Borla Stingers, MGW Orange, SCT X3, and some make it sexy mods ![]() '89 GT 5.0 w/full bolt ons-SOLD '04 STi w/ A'pexi N1 catback and accessport-SOLD '00 Audi A6 2.7t stock - DD/Wifey's whip |
12.9 @ 111.44
Don't leave it running with the belt off haha!
![]() l Custom Hotside l TurboSmart l MHS l Hallman l On3 l BBK l Hellion l SCT l Flowmaster l Steeda l AEM l Tial l HPX l Hawk l Trickflow |
i used the TOB that came with my clutch, its not commeing from the tranny, its def the font of my motor... can i start my car with the procharger off? seems like it would have bad air-fuel and wouldnt be healthy for my car...
How do i change my tensioner pulley?? it just bolted on? im changeing the whole assembly not just the pulley thanks!
Hardon Enthusiast
2008 Mustang GT
should just be 3 bolts i believe.
![]() Hurst Billet Comp Plus, Shortys, Violators, CMDPs
C&L Racer, SCT Bama 93 Race Tune MILITARY CREW |
Here's what I do - remove the belt, get a string similar to a lawn mower cord - loop it around the idler pullies and pull - listen for the noise - just be careful pulling the string. It always works for me -
ok guys, I replaced my tensioner and both idler pulleys, still have the squeal!
you just dont listen do you? You should have taken the belt off first to see if it was those pullies. Now you got the problem still there and money spent on not fixing the problem.
Spray wd40 on each pulley one at a time until the noise goes away. Then replace what needs to be replaced
it only squeaks when i rev it up, dont thing itll be safe to rev up with the procharger not hooked up...
why not, no boost, no load. Whats it gonna do? If it doesnt see boost or a load, the fuel will be altered as so
Threads Similar to: Loud Squealing noise from under the hood ekk
| Squealing noise | slvrbullet01 | 99-04 | 16 | September 4th, 2011 07:02 PM |
| Squealing noise | JU$ | 5.0 Mustangs | 18 | March 4th, 2011 06:10 PM |
| Loud squealing from Crankshaft and P0340 Code | Mizah87 | 99-04 | 2 | January 1st, 2011 06:49 PM |
| Squealing noise from cooling fan means what? | zdkel | 96-98 | 1 | November 8th, 2010 07:48 PM |
| Squealing noise under hood | hardhitter | 99-04 | 29 | August 29th, 2008 11:37 PM |
