2000 mustang gt
13.7 @102
big N/A cams good with a turbo?
i have a plan to do some big cams for my car to get it running good all motor. probably something from MHS since they have lots of testing done with their grinds. and i was wondering if anyone knows what makes a good turbo cam. i figure with my buddy knowing how to weld, and knowing a stock motor responds well to small boost numbers, i could run a very cheap turbo or two and maybe try making some headers on our own. i know someone posted their own custom headers on here i liked them a lot. so what im asking is, is an all motor camshaft ideal for a turbo cam seing there is pressure in both the intake and exhaust? im not sure if im on the right track. let me know what you think
I like boobs!!!
2000 GT convertible
dunno
No, to optimize a forced induction setup you really need a cam designed for it. This is one reason why I recently decided to NOT go turbo right now since I just dumped a pile of money into my NA build.
With FI, your intake and exhaust centerlines will move to optimize your power adder. The most significant change would be to advance your ehaust lobe to get the spent charge out sooner. With a turbo or a supercharger you don't need the overlap to scavenge exhaust with your intake. I'm seeing this perfect in my head but right now it's not coming out that great. Kinda busy at work. I hope that gives you an idea though.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
What makes a good turbo cam is minimal overlap, this helps prevent from bleeding off boost and helps build cylinder pressure. You should look at the MMR turbo cams, hands down the best and fastest in the business, here is a link to some more info, videos and dyno sheets. Something like our stage 3 is suggested for you.
New Product Release- 2V, 3V and 4V Custom Turbo Cams by MMR Stages 1-3 available MMR ![]()
Worlds Fastest Automatic Modular - 6.48@220 Worlds Fastest GT 500 - 6.99@205 , Worlds Fastest 5 Speed Mustang 8.99@154 www.modularmustangracing.com |
I like boobs!!!
2000 GT convertible
dunno
Scroll through here and look at the intake and ehaust centerlines on the different types of cams (NA, Blower, Turbo, Nitrous) and you will see what I'm talking about.
ModularHeadShop Bullet Cams NA specific cams
2000 mustang gt
13.7 @102
thanks guys ill be looking into this quite a bit.
2000 mustang gt
13.7 @102
lookin around for ideas with piping routes. and i came across a few setups with no intercoolers. It is a much more attractive route for me as i want to try and make my own setup. so with 10 psi MAX. Is that okay? DEZ racing is very close by so if it is a tuning issue im confident with his ability. i dont want to push it over 400hp.
2000 mustang gt
13.7 @102
anyone? would this be comparable to a non intercooled vortech?
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
You need an intercooler to make any good power with a turbo. The air gets even hotter because of the exhaust gases that are used to drive the compressor.
Also I used NA cams in my setup and went to stage 2 turbo cams later. Turbo cams seem to hit boost earlier and also have a harder hit when boost kicks in. NA cams took forever to spool and didn't have the umph the turbo cams do. |
12.73@111.36
That is probably because they are letting the boost out the exhaust port before the valves close.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
#10 | |
2000 mustang gt
13.7 @102
2003 Mustang GT
It really would not be worth the cost savings to run a non intercooled setup...you can pick up a decent front mount relatively cheap and fab your own piping. If you are going to go through all the work to fab the headers and such, you might as well toss a front mount on it. My .02
Sent from my Autoguide iPhone app
![]() '03 GT w/BBK CAI, MAC Pro chamber, Borla Stingers, MGW Orange, SCT X3, and some make it sexy mods ![]() '89 GT 5.0 w/full bolt ons-SOLD '04 STi w/ A'pexi N1 catback and accessport-SOLD '00 Audi A6 2.7t stock - DD/Wifey's whip |
Underground
2001 SVT Cobra
An intercooler is a must for a turbo set-up. The heat would kill your build without one.
#13 | |
2000 mustang gt
13.7 @102
#14 | |
2003 Mustang GT
CXracing has nice stuff
2004 V6 & 2000 GT
Yes. You are correct. Because NA cams are meant to scavenge both valves hang open and bleed off cylinder pressure instead of keeping all the boost it can in the combustion chamber. Which results in a weak hit of power and a slow spool time.
Threads Similar to: big N/A cams good with a turbo?
| 'Turbo Cams' Guys Get In Here | 04MidnightGT | 99-04 | 3 | January 1st, 2012 03:05 PM |
| Turbo cams | 40thAnnivGT | 99-04 | 21 | November 8th, 2011 11:45 PM |
| turbo kit..good idea or not so good?? | GTRumble | 99-04 | 41 | September 17th, 2010 12:46 AM |
| Turbo cams vrs supercharger cams | adrenaline=lifeline | 4V / SVT | 45 | October 31st, 2008 11:20 AM |
| Turbo cams vrs supercharger cams | adrenaline=lifeline | 99-04 | 7 | October 26th, 2008 01:10 PM |
