Top speed with 4.10 gears - Page 4
Old February 2nd, 2012, 02:20 AM   #61
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
Im auto with 4.30 gears and in 3rd i top around 120 mph with room to grow oncei get the 4v and rev more rpm. In 4th im good to maybe 145 at least . it will do it.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
Old February 2nd, 2012, 02:25 AM   #62
'03 GT
15@98mph :(
Macattac is on a distinguished road
Originally Posted by BoostHard1210 View Post
So can anyone tell me why when i tap my breaks at high speeds my car feels like its going to shake into pieces?
And this has what to do with gears? =)
Possibly because your brake discs are warped.
Magnaflow Catback | Steeda UDP | UPR CAI | AccuFab 75mm TB+Plenum| 14" rotors with 8 piston calipers | BMR LCA&UCA | Eibach Sportline Springs
Old February 2nd, 2012, 04:00 AM   #63
prochargedGT's Avatar
prochargedGT is on a distinguished road
my guess would also be your rotors are warped form excessive heat!
2000 Black GT: Procharged D1SC Setup Coming Soon!!
P1SC Setup @ 10psi ,424Hp & 388Tq
2000 Performance Red GT: Bone stock, Totaled
1994 Plymouth Sundance, DD
Old February 2nd, 2012, 07:35 AM   #64
Zip wants me
Durr4456's Avatar
2005 Mustang GT, 1967 GT
Durr4456 is a glorious beacon of lightDurr4456 is a glorious beacon of lightDurr4456 is a glorious beacon of lightDurr4456 is a glorious beacon of lightDurr4456 is a glorious beacon of lightDurr4456 is a glorious beacon of light
Your rotors could be mis aligned.
That mobile device thingy
The day I finish paying for my mustang will be a great day. Although I'm more likely to die before it happens. Don't be stupid like me!
Zip loves my penis.
Old February 2nd, 2012, 09:16 AM   #65
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
With stock size tires that calculates to 6830 rpms. With room to grow?
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old February 2nd, 2012, 09:54 AM   #66
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Originally Posted by Eagle2000GT View Post
Perhaps he was breaking it down in terms I'm familiar with. I'm willing to learn. Why do automatics distroy themselves when you go WOT in overdrive?
There is more to it, but I posted a little bit about that here: auto questions
Also, consider that when you're in OD, a small friction material covered band is trying to translate the torque from the engine to the driveshaft. It was designed for part throttle cruising at stock power levels, not WOT with 400+ rwhp.
Your rotors are warped.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old February 2nd, 2012, 12:39 PM   #67
I'm going On A Manhunt!
kyle2002stang!'s Avatar
2002 true blue GT
speed of time @ 88mph
kyle2002stang! is a jewel in the roughkyle2002stang! is a jewel in the roughkyle2002stang! is a jewel in the roughkyle2002stang! is a jewel in the rough
can you build your trans to handle WOT in overdrive? and im assuming a car with say 400 horsepower at the wheels has a higher top speed than it does with 200 obviously.
mac lt's, mac O/R H pipe, spintech super prostreets, JLT RAI, 14"antenna, mach 1 chin spoiler, two 12" kickers.
Old February 2nd, 2012, 12:51 PM   #68
termi_GT's Avatar
12.41@114
termi_GT has a spectacular aura abouttermi_GT has a spectacular aura about
Not really. Why would you want to? OD is not meant for hard usage.
MM FOBRA CLUB CO-FOUNDER
Old February 2nd, 2012, 04:13 PM   #69
'03 GT
15@98mph :(
OD band made of kevlar perhaps?
Sent from my Autoguide iPad app
Old February 3rd, 2012, 02:42 AM   #70
Underground
2001 SVT Cobra
BigEag205 is on a distinguished road
Originally Posted by Nightmare69 View Post
They see me trollin.........
hahaha...I was going to say, with a 5 speed i can easily go over 105; now, automatic, i have no idea. cruising at 85 im running 2900 rpm's. Once I hit fifth gear though, its like i engage the parachute and im pushing against being pulled. As someone else said, I'm terrified to go over 125 now so it doesnt bother me at all. Mine's more of a track car, but in short, yes, you can go over 105mph with 4.10's
BTW, all highway to the beach, with my built motor and 4.10's, AND driving spiritedly, i still averaged 27 mpg
Old February 3rd, 2012, 04:44 AM   #71
p4ndiamond's Avatar
14.80 No traction
Can't be that high im on an auto trans.
The O/d band cannot take it because it basically works like drum brakes to engage ..except its in fluid. When trying to hold it slips, kelvar will slip even more than a normal band. The rest of the tras (1-3 gears) uses clutch PLATES ...kinda like disk brakes . this is why you will nade it. I've done many into 4th gear but once i tuned i locked it out for good.
4-2 down shifts are bad because if the pressure is not finished releasing it creates a "park" type situation and you break the stub shaft.... you don't want a broken shaft.. you need that to haz horse powuz .
Old February 3rd, 2012, 09:11 AM   #72
Tang Stang's Avatar
Straight from the overdrive band section of Jerry's article: "...unless you have an all out race setup, don't use kevlar..."
It's as simple as this...if you're going to play around, lock out OD first.
Old February 3rd, 2012, 09:52 AM   #73
Zip wants me
Durr4456's Avatar
Unless your a manual. Then your screwed
Zip loves my penis.
Old February 3rd, 2012, 10:03 AM   #74
Tang Stang's Avatar
Old February 3rd, 2012, 10:05 AM   #75
Zip wants me
Durr4456's Avatar
Cause you can't turn off od in a manual? Right? Haha
Zip loves my penis.
Old February 3rd, 2012, 10:28 AM   #76
Tang Stang's Avatar
Are you kidding?
Old February 3rd, 2012, 11:48 AM   #77
Zip wants me
Durr4456's Avatar
Originally Posted by Tang Stang View Post
Are you kidding?
Maybe haha
Zip loves my penis.
Old February 3rd, 2012, 12:05 PM   #78
Blitz34's Avatar
13.907@99.85
Blitz34 will become famous soon enoughBlitz34 will become famous soon enough
iTrader: 11 reviews
Send a message via AIM to Blitz34 Send a message via Yahoo to Blitz34
2002 gt auto, exhaust and tune, 275/35/17 rears... 140 with a little more room on 3.27's.
Threads Similar to: Top speed with 4.10 gears
4.10 Gears Effect on Top Speed azazel529 2005 - 2010 34 March 31st, 2011 07:21 PM
1966, 289 with 3 speed trans. . wand to upgrade to 4 or 5 speed, any suggestions?? HORSMEN1995 Classic Mustangs 6 February 20th, 2009 02:23 PM
3.73 Gears -Top Speed sixty8fastback 96-98 25 April 15th, 2008 07:38 PM
Should i put 4:30 gears in my 5 speed?? Cantbeatblack 99-04 35 October 23rd, 2007 08:30 PM
Effect of gears on top speed and gas mileage? vacapro31 96-98 11 May 12th, 2007 09:47 AM
