Spark plug blowout
Old February 1st, 2012, 10:35 AM   #1
Tallballs'02GT's Avatar
2002 mustang GT
Tallballs'02GT is on a distinguished road
Spark plug blowout
Spark plug blowout on my 02 gt...now what?
Sent from my DROID RAZR using Tapatalk
Old February 1st, 2012, 10:55 AM   #2
termi_GT's Avatar
12.41@114
termi_GT has a spectacular aura abouttermi_GT has a spectacular aura about
You can heli-coil it but the best fix is a time-sert.
++ TIME-SERT Threaded inserts for stripped threads, threaded inserts, thread repair stripped sparkplug's, Ford sparkplug blowouts, threaded inserts threaded, repair stripped threads, stripped threads, inserts threaded inserts, Ford spark plug repair,
MM FOBRA CLUB CO-FOUNDER
Old February 1st, 2012, 12:07 PM   #3
GreyWarrior07's Avatar
2001 Mustang GT
8.98 1/8
GreyWarrior07 has a spectacular aura aboutGreyWarrior07 has a spectacular aura aboutGreyWarrior07 has a spectacular aura about
Time-Sert kit is the only option in my opinion, everything else is only half ass.
Here is the kit itself,
Amazon Amazon
CHECK MEH GARAGE
BAMA Performance Drag Team #9
Old February 1st, 2012, 02:13 PM   #4
2000 Mustang GT 5spd
35.9@16.99
Cabikejumper is a jewel in the roughCabikejumper is a jewel in the roughCabikejumper is a jewel in the rough
iTrader: 17 reviews
I used a spark plug re thread kit for 50.00.
Workin like a champ since.
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs
Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html
Originally Posted by RZNCAIN View Post
Thats not a Mustang, thats a V6!
Old February 1st, 2012, 03:10 PM   #5
2002 mustang GT
What is included in the kit?..where did you get it?
Old February 1st, 2012, 03:16 PM   #6
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
Tall do you use a torque wrench when installing your plugs?
Old February 1st, 2012, 04:26 PM   #7
2002 mustang GT
I never have and I've never had a problem with them..I just picked up this Stang and found out its a problem..so I'll be using one from now on..especially on the 5.4 in my f150
Old February 1st, 2012, 04:51 PM   #8
Blown 03 GT
I believe the torque is 18 ftlbs, and that is easily exceeded with a standard 3/8 ratchet. I tested it.
Old February 1st, 2012, 04:57 PM   #9
35.9@16.99
iTrader: 17 reviews
I've been told: get plugs tight. Then 1/4 turn more and perfect.
I bought the plug kit at ace hard ware. Autozone had one cheaper(bought that first) but t
I had to use a 1/2 drive and wouldn't fit in the plug wall. So I bought ace's and the 3/8 ext fit inside the repair kit and worked great.
My plug blew out with 2-3 minutes of owning my gt.
Old February 1st, 2012, 05:03 PM   #10
35.9@16.99
iTrader: 17 reviews
This one let's you use extensions instead of a socket. Which ext fit inside the plug holes.
Old February 1st, 2012, 05:05 PM   #11
1999 Mustang GT
Woodman will become famous soon enough
The Modular Ford Motors are notorious for insufficient threads. The old tight +1/4 doesn't apply. According to my Haynes Manual, it's 7-14lb/ft of torque for the plugs. So I'd shoot the middle and go for 10.
I had a plug blow out of a 1992 Protege with the 1.8L Mazda SOHC (great motor btw) and a helicoil fixed it up right. If I were going with boost, I could see spending the extra money on a timesert, but if it's stock, the helicoil should be sufficient.
Old February 1st, 2012, 05:11 PM   #12
35.9@16.99
iTrader: 17 reviews
Woodman. Thanks for correcting. Ivebeen doing the +1/4 on mine gt for two plugs changes. No issues.
Old February 1st, 2012, 06:46 PM   #13
2002 mustang GT
Thanks cabikejumper how much was that kit at ace?
Old February 1st, 2012, 06:52 PM   #14
2002 mustang GT
nevermind I seen it was 50 bucks
Old February 1st, 2012, 07:06 PM   #15
2002 mustang GT
I cannot find the kit your talking about tho..can you possibly post a link?..thank you
Old February 1st, 2012, 07:23 PM   #16
35.9@16.99
iTrader: 17 reviews
I don't have a link. But I'll look
Old February 1st, 2012, 07:26 PM   #17
2002 mustang GT
Thank you
Old February 1st, 2012, 07:34 PM   #18
35.9@16.99
iTrader: 17 reviews
Can't find the link.
But it was a like 10 year old package and idk if they even have that style anymore.
Old February 1st, 2012, 07:38 PM   #19
HamToast's Avatar
HamToast is on a distinguished road
If I'm not mistaken, on the 4.6 SOHC, there are only a few threads in the block for the spark plugs, less than on the DOHC. If you don't torque it down enough, it'll blow out like you had happen, and apparently its a fairly common issue with this motor.
Factory torque spec is 18ft lbs. Always best to not over tighten them so you don't end up with warped or fouled plugs.
As for the repair, I would only use TIME-SERTs or another brand that uses the same method. Here's a kit, I believe the 14mm thread size is correct NEW TIME-SERT 14MM X 1.25 Spark Plug Repair Kit 4412E | eBay or if you already have the tap/die you could get just the inserts TIME-SERT 44181 SPARK PLUG TAPER INSERTS 14MM X 1.25X 7MM Q10 | eBay
Old February 1st, 2012, 08:05 PM   #20
2002 mustang GT
To cabikejumper....did you have the head off to repair..or were you able to do it without pulling the head?
Threads Similar to: Spark plug blowout
A Not-So-Famous Spark Plug Blowout cschoening09 99-04 7 January 8th, 2012 09:53 PM
Spark Plug Blowout GP-SE 99-04 3 August 2nd, 2010 09:15 PM
spark plug blowout - fact or fiction? 3sportbob 99-04 10 March 29th, 2010 09:52 AM
Spark plug blowout mustang_gtr_99 2005 - 2010 5 January 25th, 2010 09:08 PM
HELP! Spark plug blowout w/ another prob Texas01GT 99-04 8 March 8th, 2009 06:32 PM
