Plans for fun street car
LinkBack (1) Thread Tools
Old February 1st, 2012, 09:50 PM   1 links from elsewhere to this Post. Click to view. #1
IsaidWOT's Avatar
IsaidWOT is on a distinguished road
Question
My original plan was for a Vortech unit, but upon further research, it won't provide a nice punch down around 2,000 rpms. That's what I'm looking for, riding at 2k and punching it and having massive torque. Is a twin screw the way?
2002 Mustang GT | Short Throw Shifter | CAI | 3.73 Gears | Exedy Mach 400 Clutch
Old February 1st, 2012, 09:55 PM   #2
SSG Pate's Avatar
00 Mustang GT Vert/88 5.0
SSG Pate has a spectacular aura aboutSSG Pate has a spectacular aura about
Your not going to get MASSIVE torque out of these small cube engines, but a Roots style blower will definately come on stronger then a centrifugal blower will at low boost, but somewhere around 3800RPM better watch out for the centris.. Are you planning a forged block? if so once you get in high boost levels i think the centris and roots are comprable especially if you have the right gearing.
Proud Iraq and Afghanistan War veteran
Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
Old February 1st, 2012, 09:59 PM   #3
No A/C FTW!
Blak GT's Avatar
2001 Mustang GT
Blak GT will become famous soon enough
Kenne Bell ftw!
Originally Posted by jbenevides89 View Post
....if dicks tasted like bacon i might have to rethink my sexuality
Looking to buy 99-04 interior parts (preferably tan) PM if wanting to sell
Old February 1st, 2012, 10:02 PM   #4
95mustangGT/SVT's Avatar
2001 Gt
95mustangGT/SVT will become famous soon enough
I may be mistaken but I believe that the on3 turbo kit kicks in pretty hard in the 2.3-3k range
Old February 1st, 2012, 10:17 PM   #5
IsaidWOT's Avatar
I was comparing torque curves and the Kenne bell had a lt of torque at 2,000 rpm. That's what I'm looking for. I may want more power later, but I think the non-ic kit is looking like its what I want for now. I won't have the money for anything more.
Old February 1st, 2012, 10:18 PM   #6
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
lol do what i did and put a 3v 5.4 in ti with a roots blower
thats a ton of torqe lol
but yea a roots blower
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old February 1st, 2012, 10:26 PM   #7
SSG Pate's Avatar
I was looking into this non intercooled Kenne bell as well when i was shopping, And Kenne belle told me to def go intercooled or i would loose alot of power to heat. just something to think about that thing running on the top of the engine with nothing to cool it down its gona get hot and rob you of some power.
Old February 1st, 2012, 10:28 PM   #8
mdb12002's Avatar
11.56@119.24
mdb12002 is on a distinguished road
You are going to run into issues if you dont build the motor, and have all that torque at lower end rpms. I recommend putting a forged shortblock in there, good luck though!
Just your average '02 GT
Stock bottom end
Slower than yours
459rwhp/415tq
Old February 1st, 2012, 10:40 PM   #9
IsaidWOT's Avatar
Would there be a lot of heat even if I keep out of the boost? And also, how bad would it wear on my stock bottom end with 6psi?
Old February 1st, 2012, 10:47 PM   #10
JerseyTrueBlue's Avatar
2001 Mustang GT
JerseyTrueBlue has a spectacular aura aboutJerseyTrueBlue has a spectacular aura aboutJerseyTrueBlue has a spectacular aura about
Guys before you start telling this dude to get a shortblock please read the other thousands of threads just like this. We all know that 400whp is safe in any fi application as long as you're intercooled or using meth, your boost levels don't surpass 10-11 psi and you keep your timing under 14 degrees. It's all about cylinder pressure/heat. So lower you're boost while cooling your IAT's at the same time by adding an intercooler. If you are talking about a 6psi non intercooled kit that is plenty safe. My guess is you'd be somewhere around 350whp with that setup, however you could get much more power/boost and be a lot safer by spending the extra cash on the intercooled kit. If you don't want to blow up your car don't cut corners when building an FI motor! Enough said!
True Blue Crew Member #2
315's Crew Member (Dat azz)
255/298
Founder of the please leave my signature alone, I want it to say what I put there and don't appreciate you deleting it club
Old February 1st, 2012, 10:59 PM   #11
mdb12002's Avatar
11.56@119.24
So building a FI motor, and not forging the internals, is not cutting a corner? hmm...
Stock bottom end
Slower than yours
459rwhp/415tq
Old February 1st, 2012, 11:01 PM   #12
MT0911's Avatar
99' Vette, 02' Mustang GT
MT0911 has a spectacular aura aboutMT0911 has a spectacular aura about
iTrader: 8 reviews
'99 SVT Cobra - 283 C.I. WAP Forged Block, HP Custom Blower Cams, Novi 2000rr (8-Rib) + 20 psi, RPM T-56, SRA Swap
'99 C5 Corvette FRC - H/C/I/E + Suspension
'02 Mustang GT - Exhaust, 4.10's, Suspension SOLD
Old February 1st, 2012, 11:07 PM   #13
cschoening09's Avatar
2001 Mustang GT
9.30 @ 77mph-1/8th mile 2.2 60'
cschoening09 will become famous soon enough
i think he was meaning if the op were to go above and beyond the 350 whp and build the engine to support more boost/power. therefore if he wants more power than what the stock bottom end can handle, he needs to build his engine and build it right.(not cutting corners).that is if he doesnt want its to blow - correct me if im wrong Jerseyblue
01 GT. 5spd , 03-04 cobra clutch, on its 2nd 4.6l motor2nd tr3650 too,JLT CAI,UPR o/r x, magnapack catback, predator tuned, H&R ss 10.5" bullitts w/ nt555r DR's
Old February 1st, 2012, 11:10 PM   #14
T-Lee. 30's Avatar
03 gt, 96 tbird, 05bv gxp
Faster than trolls!
T-Lee. 30 is just really niceT-Lee. 30 is just really niceT-Lee. 30 is just really niceT-Lee. 30 is just really nice
Send a message via Yahoo to T-Lee. 30
Centri and gears.... nah good luck with the hunt/decision
03 V1 S trim @5psi 339/359 3:73's Iraq and Afghanistan War Vet 4 deployments from 01-08.My Wife is also a War Vet
Old February 1st, 2012, 11:44 PM   #15
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
I've compared dynos from a KB and my ProCharger. Here are the results.
RPM.........KB @ 8 psi.........ProCharger
2500........165/345..............150/300 @ 1.8 psi
3000........200/355..............180/315 @ 2.6 psi
3500........240/360..............230/345 @ 3.4 psi
4000........275/362..............278/365 @ 4.2 psi
4500........310/362..............323/378 @ 5.0 psi
5000........340/360..............363/382 @ 6.1 psi
5500........370/350..............382/371 @ 7.5 psi
6000........375/330..............393/344 @ 8.9 psi
The twin-screw does in fact make more torque at low rpms than the centri. But how useful is it? With a centri I already have no traction in first on the street and the only time my motor is below 3800 rpms (the cross-over point of power from the twin-screw to the centri) is on launch. I really don't think the stress the low end torque puts on the rods is worth it.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old February 2nd, 2012, 12:46 AM   #16
T-Lee. 30's Avatar
Faster than trolls!
Spot on!
Old February 2nd, 2012, 12:52 AM   #17
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
yes a kb will constantly generate heat because it never stops spinning. also the sc is placed directly on top of the motor so it will heat soak no matter what. get an intercooled kit. as for wearing out parts. detonation kills get a good tune and less worries about problems.
bone stock from the factory!
Old February 2nd, 2012, 06:56 AM   #18
IsaidWOT's Avatar
Thanks for this Eagle! From these numbers it looks like I'd be happy with a Vortech. Reps to you man!
Old February 2nd, 2012, 07:10 AM   #19
stal94gt's Avatar
2003 mustang v6 ;)
slow
stock motor with a vortech, 10# of boost
same vortech with 16# of boost, built motor and ported heads
twin screw power curve, sorry dont have a dyno of a low hp twin screw, and this is on a 4v
imo they are both fun, flooring the car below 3k is a waste of gas so i drop it down no matter what powers my car.
Old February 2nd, 2012, 08:39 AM   #20
2003 Mach 1
glittle75 has a spectacular aura aboutglittle75 has a spectacular aura aboutglittle75 has a spectacular aura about
I love my KB, its lots of fun on the street. The difference is where the torque is, KB is off-idle instant full boost, and all the torque is there right then. Centri's spool and then usually make more peak HP. So far as your original post, and wanting all of it right when you hit the gas, Twin Screw or Roots is the way to go for you. Centri is the way to go if your car spends alot of time in the upper RPMs. I would say ride, or if you can drive, friends cars with both style blowers and see which you really want. Wanted a Procharger for the longest time, then rode in a KB Mach, and was sold. No centri's for me.
2003 Azure Blue Mach 1 - KB, Suspension, Bolt-ons.
497hp, 460tq.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/248421-plans-fun-street-car.html
Tork Tech Non intercooled kit - MustangForums.com This thread Refback February 2nd, 2012 12:57 AM
Threads Similar to: Plans for fun street car
pics from memorial day MEAN 16, TRUE STREET, AND KING OF THE STREET RACE 56K KILLER injected03stang Pictures 12 January 16th, 2012 07:56 PM
Plans jf16 General Tech 1 September 9th, 2011 04:27 AM
Plans for my GT 97GT4.6 96-98 14 November 18th, 2008 03:00 AM
Plans for the car MustangMatt96GT The Clubhouse 24 October 12th, 2008 02:12 AM
Whiteboy's 8 second street driven 280z street king Mellon Videos 3 December 27th, 2006 08:15 PM
