Service engine light - Page 2
Old February 3rd, 2012, 08:26 AM   #21
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Well, in order to keep that code from coming up repeatedly, you'll either need to turn off the secondary O2's in the tune or install MIL eliminators.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old February 3rd, 2012, 08:53 AM   #22
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
The O2 and catalyst monitoring systems can and do behave oddly at times. When I got my '03 GT in December of '06 it had an off road H-pipe, Flowmaster 40's, the stock tune, and no MIL eliminators. I drive it over 500 miles before any DTCs were thrown, then reset the PCM and drove almost 1000 miles more before they returned. They next popped up 50 miles later.
Shortly after that I replaced that absurdly and obnoxiously loud, and smelly, system with a UPX catted X-pipe and Magnaflow catback. The so-called "high-flow" cats (they are actually just cats with less "stuffing" than is really needed to scrub the exhaust) worked for about 20k miles before any DTCs were thrown. I then just "tuned-off" off the rear sensors, been that way since...
FWIW I just looked up the data sheet for the 28F010 EEPROM which is similar to the 81C65 (Ford's marking) EEPROM used in the EECV PCM.
It has a lifetime spec of 100,000 erase/program cycles (that would be re-flashing it 12 times a day for 22 years), and a 10 year (power off) data retention capacity.
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Threads Similar to: Service engine light
Battery Light/Service engine soon light Genevieve! 99-04 21 March 12th, 2011 10:51 AM
Service Engine Light DanishStallion 99-04 6 July 7th, 2009 12:56 PM
service engine soon light RC02GT 99-04 14 January 25th, 2009 07:42 PM
Service Engine Light 01VBmustang General Tech 5 January 9th, 2009 06:33 PM
Service Engine Soon Light? joka187 V6 Mustangs 7 December 13th, 2007 01:02 PM
