2002 mustang GT
Service engine light
So I installed a helicoil insert in my 02 gt...and now the service engine light is coming on..any ideas?
Sent from my DROID RAZR using Tapatalk |
MM's king of Neon's
404 - car not found
17.81@87
First step would be finding out what code it's throwing.
Find that out at either Autozone, get a scantool, or use a handheld tuner.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
2002 mustang GT
I had to head into work..so I haven't had the chance...was seeing if this had happened to anyone else
2000 Mustang GT 5spd
35.9@16.99
![]() ![]() ![]() iTrader: 17 reviews
Never happened to me when I did coil. Unllug negitive cable. And press the brakes for 30 sec. Or leave it unplugged for awhile. It'll clear it(not ready) and see if it comes back. Or just go to autozone. Or use a sct if you have one.
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html |
2002 mustang GT
Yea i'm wondering if I got something on the plug..making it not fire correctly..i'm gonna check it out on lunch break
2001 Bullitt
Did the plug actually "blow" out of the head? There could be coil or harness damage. Pulling the codes will lead you in the right direction.
Sent from my phone |
2002 mustang GT
It didn't blow out..it just started making the putting sound..didn't even move the coil pack..or harm it in any way
2002 mustang GT
Ok so the code is coming up po136..which says circuit condition..heated oxygen sensor bank..sensor 2...so that had nothing to do with the cylinder I cylinder I worked on i'm guessing
That's a code for the secondary (after-catalytic converter) O2 sensor on the passenger side (bank 1). Most likely it's either that the sensor is failing or the catalytic converter is failing. How many miles are on the car? Stock exhaust?
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
2002 mustang GT
Its got 75k on it..and it has an h pipe..either bbk or flowmaster..plus full exhaust after..I recently purchased and I can't remember exactly what the guy said he installed
Is it an off-road h-pipe? If so, it either needs the secondary O2 sensors turned off in the tune, or they need to be replaced with a pair of MIL eliminators.
2002 mustang GT
Ok..i'm curious in why all the sudden I would get bad gas mileage and loss of performance..wouldn't that happen right after the exhaust wad put on?
We really need the full details of what all is going on with your car. Didn't you just blow a spark plug, too? When did the bad gas mileage/performance loss occur? Does the H-pipe have catalytic converters, or is it an off-road h-pipe? Does it have MIL eliminators? Has the car been tuned? Etc, etc. If you want good answers, you need to give us all the pertinent information.
2002 mustang GT
Yes I did have a spark plug blow out..i.repaired that last night..then right after I fixed it and test drove it..the light came on..I've noticed not so great gas mileage before the plug port repair..but i'm thinking it was cause if the loose plug..after I fixed it I can tell a performance change..it doesn't have cats..and i'm not sure about the mil eliminators our the Tune..i'm trying to find it from the dude I bought it from
In that case, it sounds like the P.O. stuck a offroad h-pipe on the car and just left the secondary O2's unplugged.
2002 mustang GT
But wouldn't that have set it off immediately?..i'm wondering if I did anything to mess that up during the thread repair..but its coming up on the opposite side if the motor..I worked on cylinder 6
did you unhook the battery when you did the work? you may have reset your computer. Might have had a tune in it.
2002 mustang GT
I did have the battery die from the cold earlier this late last year..and that might have been when I started getting bad gas mileage..does that mean I have to buy a tuner to get back my gas mileage?..anyone got one for rent?..lol
The battery dying would not affect the tune, it is stored in an EEPROM (Electrically Erasable Programmable Read Only Memory) with a power off data retention capacity of 10 to 15 years, minimum.
Not having cats would cause the P0136 code (others may pop up) if the rear sensors are not disabled in the tune. It may be that the PO did turn them off, but returned the tune to stock before selling the car so as to "unmarry" his tuner. Also it can take 100 to 200 miles, or even more, for the catalyst monitor to complete its tests and throw the DTCs. The tests are only run when certain conditions have been met, for specified periods of time (read more about the cat monitor here). One last comment. Clearing the KAM (Keep Alive Memory), which stores all adaptive learning tune parameters--fuel and idle air trims, etc.--requires that the battery be disconnected for 5-7 minutes. Disconnecting it and stepping on the brake for 30 seconds will discharge the airbag system's backup power (a large capacitor), however it will not clear the KAM which has it's own memory retention backup supply.
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
2002 mustang GT
Wow..that's some good info..thank you..the battery could of been dead for a couple days..i'm not sure..but I take it it don't matter..as for the code PO136..I've put on a coupe thousand miles since I bought it..
Threads Similar to: Service engine light
| Battery Light/Service engine soon light | Genevieve! | 99-04 | 21 | March 12th, 2011 10:51 AM |
| Service Engine Light | DanishStallion | 99-04 | 6 | July 7th, 2009 12:56 PM |
| service engine soon light | RC02GT | 99-04 | 14 | January 25th, 2009 07:42 PM |
| Service Engine Light | 01VBmustang | General Tech | 5 | January 9th, 2009 06:33 PM |
| Service Engine Soon Light? | joka187 | V6 Mustangs | 7 | December 13th, 2007 01:02 PM |
