problem with fuel trim
Old February 2nd, 2012, 10:14 AM   #1
tom46's Avatar
2001 mustang gt
14.0
tom46 is on a distinguished road
i have a 2001 mustang gt with all the bolt ons. i have a fuel trim problem with a random missfire. fuel trim is -15% . all normal test performed and check out good. but when u take the oil cap off at idle. the fuel trim goes down to 1. i put a new pcv in it and checked for cloggs . nuthing no change in fuel trim. does anyone have an idea whats going on with my car. i do have the stock plastic intake manifold.
2001 mustang GT --- 373 gears, pullys, 70mm throttle body, upper intake plenum, cold air intake system,bbk long tube headers, catless H-pipe to super 40 flowmasters, cobra R rims, sound system , HID headlights, grills
Old February 2nd, 2012, 01:43 PM   #2
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Has the car been tuned? Opening the oil fill while the engine is running introduces un-metered air and will effect the fuel trims.
Is the list in your sig the complete extent of the mods done to the car? You haven't changed fuel injectors or the MAF without tuning, right? Have you cleaned the MAF recently?
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old February 2nd, 2012, 11:47 PM   #3
tom46's Avatar
2001 mustang gt
14.0
the MAF is reading right and i had a tune in it. the fuel trim was at 25% then i took the tune out and put it back to the stock setting and the fuel trim changed to -15%. i changed the pcv valve it droped to -10 %. the shop wanted to try somthing with the computer so they reloaded a stock setting on the car to make sure it was a true stock setting and then the fuel trim went to 5% and under. thats with no tune and long tube headers. im going to drive it for a week and if nuthing changes im going to retune the car and see what happens
Old February 3rd, 2012, 02:32 AM   #4
bulloch27's Avatar
2003 Mustang Fauxbra
N/T @ Fast
bulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the rough
The fuel trim should be constantly changing with a target of 0. Rich conditions, as read by the O2 sensors, will result in a negative fuel trim value and lean conditions will result in a positive fuel trim value. If you're maintaining a negative fuel trim I would suggest looking at the output value of the O2 sensor for that bank of injectors with the negative value. You may find that you're not getting a proper reading out of that O2 sensor and that replacement may remedy the problem.
All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now?
03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold
Old February 3rd, 2012, 04:45 AM   #5
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
you may need a tune for your long tubes. relocating the o2 sensors down stream can require the heater ranges of the 02 sensors to be changed.
bone stock from the factory!
Threads Similar to: problem with fuel trim
WOT Short Term Fuel Trim p4ndiamond 96-98 20 January 3rd, 2012 02:38 PM
P0173 - Fuel trim Malfunction Bank2 Starfish_Ninny 99-04 5 May 27th, 2011 02:37 PM
How to read short term fuel trim KevinJ99GT 99-04 5 May 20th, 2010 06:42 PM
p1150 fuel trim at level dtc??? need answers! o2gtstang 99-04 7 September 20th, 2009 12:37 PM
Sniper Recon fuel trim fix... cliffyk 99-04 4 June 18th, 2008 11:50 AM
