radiator light
Old February 2nd, 2012, 12:48 PM   #1
erthing i do i do it big
99gtpony's Avatar
1999 mustang gt
havent gotten the chance to run yet.
99gtpony is on a distinguished road
radiator light
My radiator light came on idk why but it is saying add coolant but its full I've looked at the sensor and it looks good idk how to get the check radiator light to go off
Any help plz
Old February 2nd, 2012, 05:02 PM   #2
shanerob34's Avatar
13.70@99.18
shanerob34 is on a distinguished road
ive done just a quick little bit of research for you and I've come to my conclussion(without checking too far) that it is a common problem for the coolant sensor to go bad on these and need replaced. You cant just buy the sensor though you have to buy the whole tank.
Up & Coming
BAMA Performance Drag Team #10
Old February 2nd, 2012, 05:14 PM   #3
2000 Mustang GT 5spd
35.9@16.99
Cabikejumper is a jewel in the roughCabikejumper is a jewel in the roughCabikejumper is a jewel in the rough
iTrader: 17 reviews
I just unplugged mine.
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs
Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html
Originally Posted by RZNCAIN View Post
Thats not a Mustang, thats a V6!
Old February 2nd, 2012, 08:28 PM   #4
995SPDGT's Avatar
1999 Mustang GT
995SPDGT is on a distinguished road
How long has it been since you changed your coolant? I had the same problem with my car, believe it or not, if your coolant is weak or has more water than coolant the level in the coolant reservoir will sink to the bottom and stay there.. Change your coolant and it should fix the problem. It did for my Mustang and my Dads.
Old February 2nd, 2012, 08:38 PM   #5
shanerob34's Avatar
13.70@99.18
someone correct me if i am wrong, which i may be, so this is more like a question. I thought the way the sensor worked was by passing an electrical current(or something like) from one end of the sensor to the other. and that is used the coolant to transfer the flow. and that unplugging it wouldn't work.. this is what i thought but i could be wrong or am not wording it properly
Up & Coming
Old February 2nd, 2012, 09:13 PM   #6
95mustangGT/SVT's Avatar
2001 Gt
95mustangGT/SVT will become famous soon enough
If you have a tuner you can clear it, but it may just come right back on. I would pull the gauges out and pop that bulb out. I keep an eye on my temps and collant levels though.
Old February 29th, 2012, 02:07 AM   #7
99gtpony's Avatar
1999 mustang gt
I did this it worked I am keeping an eye on my coolent and temps so light is off and everything is good thanks everyone for the help
Old February 29th, 2012, 02:49 AM   #8
86er's Avatar
its a float, when the floats up, it reads/see's full. When it drops its empty, or too much water, as stated above.
They are prone to getting stuck and not moving. Give the tank a light tap and see if it loosens up, if not, get a screw driver etc and just give it a wiggle through the filler cap
Just a truck
Old February 29th, 2012, 03:29 AM   #9
99gtpony's Avatar
1999 mustang gt
Haven't heard of that. I can check to see if that works tomorrow afternoon if not ill just un plug it again lol I got my oil changed the other day and he told me I had to get a whole new tank and sensors... Sounds like you don't have to be that smart to be a mechanic in Missouri :p
Threads Similar to: radiator light
Will these work for LED Tail light/reverse/turn signal/fog light bulbs? 02BlueMustangGT 99-04 0 January 24th, 2012 09:51 PM
Battery light and Radiator light on cobra99svt 96-98 5 June 23rd, 2011 01:16 PM
99 mustang gt radiator light is on! heeeelp 0di3 99-04 6 October 16th, 2007 11:10 PM
Ok Two Questions for you! Cluster and Radiator Light 0di3 99-04 1 May 23rd, 2007 08:19 PM
