MM's king of Neon's
404 - car not found
17.81@87
Install New Radiator Draincock?
On the list of many stupid things my PO has done, one is the radiator draincock. Where it should normally be, there's just a massive glob of epoxy. I can only assume he broke it off, and just plugged it.
Does anyone know if there's a suitable location I could drill and tap the radiator for a new one? Or am I SOL and need to get a new radiator? It's not like it's a terrible thing, just an inconvenience. After all I drained it before from the water inlet hose. But if I need to replace it, now is the time before I fill it up with coolant and fire it up. If I do have to replace, it's going to be a pain. The junkyard in town has exhorbitant prices (they wanted as much for used COP's as they were new!), the one south of here actually refused to sell me parts, and going up to Indy is a gamble if they have any Mustangs, not to mention Superbowl traffic this weekend. Any input is greatly appreciated.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
wiggety wiggety whack!
I'm surprised the epoxy even held. What about one of those lever on/off oil drain plugs? I haven't heard great things about them but you could just drill out the epoxy and epoxy this one in the same spot, this is what I'm thinking about:
QuickOilDrainValve.com - the best way to change oil |
MM's king of Neon's
404 - car not found
17.81@87
Sourcing a draincock is no problem.
The hard part is installing one. I'm unsure of the end tank sheet metal thickness so I'm unsure if I can drill/tap it. Not sure if I'd roll the dice in drilling the epoxy either. I'll snag some pictures today. It will be good for some laughs.
Proud American
New radiators from Advanced auto parts are really reasonable for these cars.... But he'll you could buy a be cool or a Griffen and never have to worry bout it.
08 GT
You can get a new one from RockAuto for $100 to $130. I have never had a problem with anything I've got from them...
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
#7 | |
MM's king of Neon's
404 - car not found
17.81@87
In that case the plastic may support a draincock. I think I might just drill a hole and epoxy in a new draincock. Although I might actually do this the correct way, unlike the PO. ![]() I've got no problem with new parts from Rock Auto, but remember, this here is a junkyard build (albeit a very fast junkyard car) and I'm going to try and fire it up this weekend.
#8 | |
#9 | |
MM's king of Neon's
404 - car not found
17.81@87
I also think "Frankenstang" is an appropriate name for this monstrosity. Third motor (that I know of), very little makes sense on it. Lots of parts from all sorts of cars (Cobras, MKVIII's, Crown Vic's, GT's, fabricated). The radiator has definitely been effed with at some point (like much of the car). The whole A/C condensor core is gone, most of the A/C setup is still intact. I probably should eventually go to a better radiator. This one is the stock 4.6, but it seems pretty wimpy. Add to that the fact I'm going to be dumping a whole lot more heat from a higher power motor with bigger heads and a big fat dual pass HE that's in front of it, and it would probably be a good idea.
Threads Similar to: Install New Radiator Draincock?
| Mishimoto Radiator / Dual 12" Install | jk_aktion | 99-04 | 11 | April 3rd, 2012 01:03 AM |
| Radiator install | NatesGT | 96-98 | 3 | December 19th, 2010 09:09 PM |
| steeda radiator support install??? | MM5522 | 2005 - 2010 | 2 | November 29th, 2010 09:27 AM |
| Quick questions about AT radiator install! Help! | BurninRubb3r | 5.0 Mustangs | 4 | January 15th, 2010 10:21 AM |
| 01 Radiator install | HMUSN | 5.0 Mustangs | 24 | July 22nd, 2008 08:30 PM |
