Teksid 2V timing set question
Old February 2nd, 2012, 04:58 PM   #1
08 GT
laser46 is on a distinguished road
Can the timing set on a Teksid be used with 2V heads and stock 2V cam sprockets? Using just the primary chains, crank sprockets, etc. of course. Reason I ask is because I have a bare Teksid and found this timing set: eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices Anybody know for sure?
Old February 2nd, 2012, 05:23 PM   #2
2001 Mustang GT Vert.
cbjohnson9 will become famous soon enoughcbjohnson9 will become famous soon enough
The 2V cam sprockets can be used on any mod motor with 2V cams. I'm not sure the primary setup for the 4V motors is the same as timing setup on the 2V motors. Judging by the picture, I'd say the tensioners, and guides are the same. If I had to guess, I'd say you would need a different chain.
Personally, I wouldn't buy this stuff used. I would only buy new OEM stuff. Make sure the tensioners are full steel (no plastic) and the guides with the aluminum backing are an added security.
I bought a full OEM timing set from MHS.
Did you drill the coolant passage needed to run 2V heads on the teksid block?
Mods in garage
Old February 2nd, 2012, 06:05 PM   #3
08 GT
No, I haven't drilled the coolant hole yet. Still in the parts collecting phase. I was hoping the set I linked to would work particularly because it includes all of the bolts needed, none of which I have. I have to agree that new chains would be a good idea.
Anybody else have any input on this?
Old February 2nd, 2012, 07:27 PM   #4
86er's Avatar
crank sprocket will work, the primary cam sprockets are the same, the chains, guides, tensioners all the same. The dohc secondary chains etc are the only difference.
Just a truck
Old February 2nd, 2012, 07:52 PM   #5
08 GT
That's what I was hoping. I mean they do call them modular for a reason. Thanks for the info.
Threads Similar to: Teksid 2V timing set question
97 cobra teksid block question scr110 4V / SVT 2 January 6th, 2009 03:56 AM
Question about Timing Traidmarx 5.0 Mustangs 25 September 26th, 2008 07:53 AM
Timing Question jagstang96 96-98 5 December 23rd, 2007 09:25 PM
Question On Timing With NOS Newtgadget 5.0 Mustangs 37 December 17th, 2007 06:32 PM
Timing Question USMC8511 5.0 Mustangs 4 June 19th, 2007 07:26 PM
