00 Mustang GT Vert/88 5.0
Axles
Thinking about 28 spline forged axles, for those of you who have done this is 28 Spline forged suffiecient for a street car. Dont want to upgrade the whole thing if its not needed, as i have other projects taking off to.
![]() Proud Iraq and Afghanistan War veteran Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
"Street car" doesn't tell us much. What mods (current and planned), how much power do you expect to be putting to the ground?
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
im putting down 550 RWHP through a 4r70W dont plan on getting much more then 600RWHP by the time its all said an done.
2003 ford mustang gt
13.9 stock
sub'd; also considering this, i will be running sticky tires at track putting about 265rwph tho sorry to tread jack op
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
You need 31 splines. Moser, Strange, Superior are good. I have Moser. One local guy was running Superior's for 10 years and just snapped one at the track this summer. Car was making right around 500rwhp.
![]() 2003 DSG Mustang GT 5spd Full Bolt On's, Suspension, Built Rear, V1 S N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60' Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60' Intercooled: 362/370 |
Then I would upgrade, or just wait 'til one breaks and then upgrade to a 31-spline setup...
#7 | |
NON-IRS 8.8" RING & PINION INSTALLATION KIT - Buy Ford Racing 8.8 TRACTION-LOK LIMITED SLIP DIFFERENTIAL 31T Moser 31 Spline Mustang Axles for 8.8in Rear w/ Studs (99-04 GT, Bullitt, & Mach 1) A883153 - Free Shipping! Royal Purple Max Gear 75w90 Mustang Gear Oil 1300 - Free Shipping!
#8 | |
Yup. Had American Muscle linked first lol.
04 mustang gt
7.21 @ 98
i'd throw the 28's in and wouldn't worry IMO. auto is way easier on the rear than the 5spd...and you won't ever hook good enough on the street to break an axle anyway.
![]() cams + 150 shot |
Well Right now I am looking for some Mickey thompson tires as well to to on the 17x10.5 Chromw bullitts i just bought. So i might be hooking up after all. i was thinking 315's but not sure if they will fit under the car.
04 mustang gt
7.21 @ 98
they will fit as long as the car isn't slammed on the ground.
12.73@111.36
I agree with the above posts. You're running too much horsepower for a 28 spline differential. I've read that Explorer differentials with hardened 31 spline axles holds up well. That's what I went with.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
2003 Mustang Fauxbra
N/T @ Fast
This.
![]() All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now? 03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold |
The Mean Green
+1 to needing a 31 spline setup with that power. I'd wait until the stock one breaks, you'd be surprised at the abuse a stock rear can take. Mine took plenty of abuse on the street and strip. But 4-5k rpm launches on slicks finally broke it. I went with a 31spline diff from a newer stang, added the carbon clutches (easy mod) and moser axles for just a few hundred bucks.
Threads Similar to: Axles
| SN 95 Axles vs Fox | 88notch393 | 5.0 Mustangs | 7 | December 9th, 2008 04:48 PM |
| Axles | adrenaline=lifeline | 99-04 | 1 | December 2nd, 2008 07:25 AM |
| Axles... | 06GTMustang89 | American Muscle | 1 | October 15th, 2008 02:12 PM |
| axles | njstang | 99-04 | 5 | May 10th, 2008 01:42 AM |
| Hp and axles .?.?.? | Montanasvt | 4V / SVT | 30 | February 4th, 2008 11:46 PM |
