2002 mustang gt
![]() iTrader: 1 reviews
C CLIP ELIMINATORS
How do c clip eliminators work? Do the bolt to the axles? Lol how do the hold them in?
Rock stock
02 gt coupe
They are pressed onto the axle shafts and then bolted to the end of the axle tubes where the backing plates bolt up....I haven't done any on a new edge but the ones I've done (ford and chevy) u have to cut a certain amount off the ends of the axle tubes. The c clip eliminator is your new axle bearing/seal
For sale...vortech 6 rib 3.6 pulley new..55 shipped Vortech 6 rib 3.48 pulley 100 miles on it..50 shipped used aviator pump with 80k..50 shipped 01-04 steeda underdrive pulley set...about 200 miles on it before going s/c 160 shipped |
2002 mustang gt
You have to cut some off? How much are we talking about? I just oredered some so it would have a bunch, you'll get rep'd
Rock stock
02 gt coupe
Its not that much....maybe about 3/8 of an inch...but once u do it u can't go back...the reason u cut some off is to clear the c clip eliminator so it can sit flush
2002 mustang gt
Im not understanding why it wouldn't sit flush in the first place
Rock stock
2002 mustang gt
Well I did some research... so how do I go about cutting the tubes to get it to fit?
Rock stock
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
you have to have someone put it on a jig and cut the ends off, to make sure it sits even. You also have to take the plate that holds the caliper to the axle end to a machinist who will have to shave it flat by 1/8". Its a lot of work and your ABS will have to be deleted since you are cutting the ABS ring off the rear end.
2000 Mustang GT Built 4V Motor with Sullivan Single Plane Intake Custom 66MM BB TT kit Borla XR-1 Dumped before rear Moser built 9" Rear 35 spline WaveTrac Diff with 3.75s 35 spline Moser axles 14PT roll cage and minitubbed
02 gt coupe
The c clip eliminators are thick that's why they wont fit over the ends...but honestly what is your reasoning for buying them....at your power level I don't think its necessary unless u are dead hooking at the track and dumping the crap out of it....if anything just upgrade to 31 spline axles and posi unit
02 Mustang GT
9.91@133
No cutting with this setup.
Strange Engineering
2002 GT PI heads Twin 60mm turbos Th400 6.34@114 1/8 9.99@137 1/4 http://i160.photobucket.com/albums/t...t/DSCF5654.jpg http://i160.photobucket.com/albums/t...2gt/IMG060.jpg |
11.463@121.50
I think if you want to run in the 10s you need the c-clip eliminators, no?
I'd like to get rid of the ABS and the traction control all together.
MM Bracket Racing Crew Member #5 |
2002 mustang gt
I got rid of my abs a long time ago so I wouldn't need the abs ring anyways, so far I think I can make my brakes work, I forgot my axle seal/bearing puller at work so ill hold off on the rest until tomorrow
Rock stock
#12 | |
2002 mustang gt
I wish I would have read that before I did some cutting!!!!!
Rock stock
2002 mustang gt
Btw...what's a good way of getting the abs ring off the axles?
Rock stock
02 Mustang GT
9.91@133
I only had my bracket machined....
2002 mustang gt
Do you have the ones in the link you posted?
Rock stock
02 Mustang GT
9.91@133
No, the ones I have needed the brackets machined. I had it done like 4 years ago.
2002 mustang gt
I was going to make my own, I just need to get my bearing puller from work and call it a day
Rock stock
1997 Pacific Green Cobra
14.80 No traction
I like them allot. but i see once in awhile i get leaks on the ends of the tubes. Nothing too bad tho.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
2002 mustang gt
Did you install yours yourself?
Rock stock
Threads Similar to: C CLIP ELIMINATORS
| Detroit truetrac with c clip eliminators?? | Cloud Nine | 5.0 Mustangs | 3 | March 6th, 2011 01:06 AM |
| which c clip eliminators ?? | UPRNewEdge | 99-04 | 1 | January 28th, 2010 12:37 PM |
| axles and c clip eliminators | mounder27 | 99-04 | 4 | June 7th, 2009 03:02 PM |
| C Clip Eliminators ? | haveav8 | 5.0 Mustangs | 5 | January 4th, 2009 10:41 PM |
| c-clip eliminators | flamestang | 5.0 Mustangs | 0 | March 11th, 2008 10:11 PM |
