2001 Mustang Cobra SVT
oil leak :o
alright just started parking my mustang on the concrete lately and i noticed about three, 1 1/2 diameter spots of oil a day on the concrete... no good. i looked underneath my car and there is only oil on the left side of my undercarrage. i think its coming out of my valve cover gasket, but what are the other possible places it could leak from besides the head gasket?
2001 Bullitt
The oil filter is on the left side. Hopefully its something that easy. Depending on mileage it could be any of the gaskets.
12.73@111.36
It would be best is you didn't say left or right but said passenger or driver's side. Left to me is the left side as I look at the motor--the passenger side. To someone else its the driver's side.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
1999 Mustang GT
N/A
Jack ur car up and look, if nothing is obvious clean ur motor and then monitor. I have the same problem and just finished cleaning my motor. I marked my garage floor where my front tires are, that way I can see where to start looking. + 1 on the passenger or driver's side
#5 | |
but anyways you're gonna have to look around before you think it's one gasket. buy a can of brake clean or two, clean off all the leaked oil, start the car and let it run for a little bit while checking it to see if you can see any drops dripping.
![]() '00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come. '95 GT, 347, tko, etc-11.8@116-sold. ![]() WTT-my mildly built 4r70 for t56/tko. |
MM's king of Neon's
404 - car not found
17.81@87
Another helpful tip is spray some white spray paint in the area you suspect might be leaking.
It was an old trick my dad taught me when I first got my Cutlass. Wipe everything clean, hit a few spots with white spray paint. Since most leaks are so small you can't see it dripping or flowing, the white shows the residue very well. I'd usually hit the oil pan around the drain plug with some paint. That way after you change the oil and wipe it clean, it's easy to tell if that's the area that's leaking after an oil change. Just a helpful tip.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
Threads Similar to: oil leak :o
| Oil leak help... | Kohrs93 | 99-04 | 15 | May 3rd, 2012 11:20 AM |
| Gas Leak | gt_andy | 99-04 | 10 | August 25th, 2011 08:38 AM |
| Anyone else have a leak - | khaos | V6 Mustangs | 10 | March 22nd, 2011 02:56 PM |
| Vac Leak Help???? | fofiddykid | 96-98 | 17 | March 24th, 2010 09:57 AM |
| Evaporative Emission System Leak Detected (very small leak) | Juggalo_X | V6 Mustangs | 11 | April 25th, 2007 04:46 PM |
