LinkBack (1) | Thread Tools |
#1
1999 Mustang GT
Missing under load, raw gas smell at idle, COP issue?
1999 Mustang GT, CAI going into fenderwell, no other engine mods.
So it's been warm up here in Minnesota, so I pulled the Mustang out last weekend and took it for a drive on Sunday. Started missing mid drive, no CEL, but I did notice a smell of raw gas. Car has 115K on the clock, Probably still on original plugs, and it has a mix and match set of coils, 5 OEM, 2 Accel, 1 MSD. I'm going to go ahead and clean the MAF (any reccomendations as what to use? I have electronic contact cleaner here at work, or if there is a specific product I'll get some), pull and change the plugs (if needed, and I will check the gap as well), and I'm wondering if my SCT will tell me what is misfiring without a CEL, or should I go ahead and just replace all 8 since it's not too bad. If I replace all 8, do I go with the Accel set on AM's site, or do I go to Rock Auto and get one of their brand. I noticed no Motorcraft brand on Rock Auto. Any other possibilities? I'll check to make sure there's no water in the plug wells too. Thanks in advance. |
N/a
I run jegs brand cops on my car they are great and cheap, but I have only ran them for about 5000 miles, most will say if you have the money buy the motorcraft cops they are suppose to be the most reliable, as far as the Maf it sounds like the cleaner you have should do fine, and I would recommend NGK plug for the car and just get the coppers!
Your car must be fast because I was hauling ass when I passed you in my Mustang! |
01 Mustang Gt
![]() iTrader: 1 reviews
My car was missin and I changed all 8 coils and problem fixed? GL
#4 | |
1999 Mustang GT
Thanks. |
1999 Mustang GT
Found the problem... The previous owner put a coil back in that had no boot. No idea how it ran so long without it, but she's running on all 8 now.
Is it normal for the stock PI intake to slightly shroud the spark plug well on the second to last plug on the passenger side? Thought that was odd. |
#6 | |
2002 Mineral Grey GT
3.7589@2
1999 Mustang GT
I was getting cold at that point, so I put changing that plug for another day. All the rest of the plugs were in great shape, just had mileage on them, so I figured leaving it in for a test run wouldn't hurt anything. Not quite sure there's enough room for a standard spark plug socket in there, but I'll see if I can get a pic when I'm working on it next.
If they are original plugs they should have been changed 15k miles ago...
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
2001 Mustang GT
9.30 @ 77mph-1/8th mile 2.2 60'
![]() iTrader: 3 reviews
cliffyk, i really like your interior lol
01 GT. 5spd , 03-04 cobra clutch, on its 2nd 4.6l motor 2nd tr3650 too,JLT CAI,UPR o/r x, magnapack catback, predator tuned, H&R ss 10.5" bullitts w/ nt555r DR's
3.7589@2
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/248607-missing-under-load-raw-gas-smell-idle-cop-issue.html
| Thread vs commodore missing under load | Just Commodores - Holden Commodore Discussion Forum | BoardReader | This thread | Refback | March 31st, 2012 03:56 PM | |
Threads Similar to: Missing under load, raw gas smell at idle, COP issue?
| Car stutters under load and idle issues | Gerbig | 99-04 | 38 | February 7th, 2012 11:41 PM |
| missing at idle with nitrous plugs | KevinJ99GT | 99-04 | 5 | April 23rd, 2011 12:34 PM |
| Missing on idle | Dennzden | 94-95 | 4 | October 12th, 2010 09:56 PM |
| missing at high rpm and idle | rayymann998 | 5.0 Mustangs | 2 | July 1st, 2010 02:16 PM |
| missing and rotten egg smell. | KevinJ99GT | 99-04 | 24 | December 16th, 2008 08:24 AM |
