MACH THIS!
2004 Mustang Mach 1
Transmission/Clutch Question
Does anyone have any issues engaging into first gear while pressing the clutch all the way in? But when you slightly release the clutch it slides into first? If so is that a clutch issue or something else?
Sent from my Autoguide iPhone app
![]() BBK LONG TUBE HEADERS BBK O/R X-PIPE BBK TWIN 62mm THROTTLE BODY STEEDA UNDER DRIVE PULLEYS SLP LOUD MOUTH II SCT CHIP TUNED BY ALTERNATIVE AUTO by Lidio SCT X3 PROGRAMMED BY BAMA TUNING JLT COLD AIR INTAKE PRO 5.0 SHORT THROW SHIFTER |
I like boobs!!!
2000 GT convertible
dunno
I would try servicing the transmission first. Drain it and fill it with 3.5 qts of synchromesh
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
2003 Mustang GT
8.26@83.06 (1/8)
Mine is sometimes hard to get into either first or reverse (which I think is a synchronizer issue). If it won't go into first, I'll put it into reverse and just barely let out on the clutch until the car moves ever so slightly (and vice-versa with reverse and first). Then, it's no problem to get into gear.
If the above doesn't work for you, do as Nick said above.
![]() SLP :: SCT :: Eaton :: Maximum Motorsports :: Baseline Suspensions :: Strange Engineering MM Bracket Racing Crew BAMA Performance Drag Team #1 Project Thread :: YouTube Channel |
MACH THIS!
2004 Mustang Mach 1
I had a mechanic change out the transmission oil and rear end oil about a year ago. I don't do a lot of driving with the mustang.
!FACEPLATED!
its pretty much normal with any manual transmission. Sometimes all the teeth of the gear, the synchronizer and the blocker ring dont line up perfectly to allow it into gear. when you let up a little on the clutch, it allows the internals to turn just enough to get them to line up and engage it in gear.
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
MACH THIS!
2004 Mustang Mach 1
But that never happened when I fist bought my car off the show room floor 8 years ago.. LOL
your clutch cable may have stretched a little causing this issue, but if you dont drive it much Thats probably not it. It is quite common though.
MACH THIS!
2004 Mustang Mach 1
I guess I'll take it to a mech to see what he can come up with it. But from what he said it could be possibly a synchro because it only happens in first and second gear.
MACH THIS!
2004 Mustang Mach 1
So after going to the mechanics he told me that I need to replace the clutch, the throw out bearing, the blocking ring, and the synchro.
!FACEPLATED!
if your going that far you might as well just do a whole rebuild of the trans
MACH THIS!
2004 Mustang Mach 1
Well he said it might be a couple grand. How much is a full rebuild?
2000 Mustang GT 5spd
35.9@16.99
![]() ![]() ![]() iTrader: 17 reviews
What trans is it. I 'think' the t45 always had 1 and reverse issues. My t45 hates going into rev.
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html |
MACH THIS!
2004 Mustang Mach 1
I got the T3065 or something along the lines of that.
01 GT Conv
It might be worth it to try a Mobile 1 fluid change first. The trans in your car is a great one, but a little picky about fluid type and level (3/4 inch below fill---if it is a TR3650.)
Official member of the anti ethanol-laced gas crusade.
Threads Similar to: Transmission/Clutch Question
| clutch and transmission fix | Chris747 | 99-04 | 10 | April 13th, 2011 02:17 PM |
| Transmission & Clutch Question | Headrage | 99-04 | 13 | January 12th, 2011 01:59 PM |
| Transmission or Clutch? | TimboStang | 2005 - 2010 | 12 | February 18th, 2009 08:00 PM |
| 95' Clutch, Transmission | /\/ew/\/oise | V6 Mustangs | 0 | March 19th, 2008 04:37 AM |
| Transmission Clutch Cable Question | kuskye25 | 5.0 Mustangs | 25 | December 24th, 2007 12:04 AM |
