I'm going On A Manhunt!
2002 true blue GT
speed of time @ 88mph
hood pins
i read alot of old threads on hood pins and every single one involved welding a nut onto the core support. i dont have a welder so cant i just buy some 5 inch pins instead of 4 inch?
mac lt's, mac O/R H pipe, spintech super prostreets, JLT RAI, 14"antenna, mach 1 chin spoiler, two 12" kickers.
Wyatt's #1 Slut
N/A
Im not sure what answer you are looking for..
There are hood pins where you just drill a hole in say the radiator support and the bottom of the pin (opposite of the end that sticks through the hood) has threads that will sqrew into the hole you drilled in the support. So, no there's no reason for welding. |
2000 GT
N/A
You just have to buy a longer pin I'm not sure on the size though but I think the 4 inch won't work
2002 true blue GT
Wyatt's #1 Slut
N/A
1/2" diameter may look dinky..
2002 true blue GT
what diameter you think would be best? just as long as theyre 5 inches and come with lanyards im happy
Wyatt's #1 Slut
N/A
I'd look for something a little bigger..
#8 | |
2000 GT
N/A
MM's Taint Shaver!
2003 Mustang GT
They are all 1/2" in diameter. OP Those should be long enough! The problem people have with the 4" pins is that they aren't long enough to reach through the hood, when placed where the bump stops are on the core support.
2003 GT
I may be wrong, but i thought only the frpp hood pins were too short? On mine I made a small bracket and welded it on, with a hole drilled through. Gave an extra inch of height and looks way cleaner than a nut welded on.
03 GT CAI, catted H pipe, SSS adrenaline catback, 75mm TB, UDP, lowered, strut tower brace, hurst short throw, nitto drag radials |
MM's Taint Shaver!
2003 Mustang GT
The FRPP's are the the ones talked about the most around here and I'm not sure if any other brands make their pins 4" long also.
Banned from AFM member!
1999 Mustang 2v 4.6L
It's about a billion times easier to weld 'em. Have fun with that.
1999 2v 4.6L 380 RWHP/ 362 RWTQ, Tuned by Fastlane Motorsports Peace - That brief, glorious moment in history when everyone's standing around reloading.
2002 true blue GT
i ordered the 5 inch moroso pins that i posted in the link above.
Threads Similar to: hood pins
| Aftermarket fiberglass hood. Hood pins or factory hood latch??? | Saleen0101 | Modular Mustangs | 11 | November 9th, 2011 04:09 PM |
| Moving Hood Pins in preparation for new hood. | RZNCAIN | 2005 - 2010 | 0 | May 26th, 2011 01:46 AM |
| hood latch keeps failing... other alternative than hood pins? | R3dFyre02 | 99-04 | 2 | June 12th, 2010 04:41 PM |
| Hood Pins install in outer hood stops? | krispyrob | 2005 - 2010 | 61 | September 27th, 2009 11:13 PM |
