01 GT Conv
S197/New Edge Rear Assemby Swap Question
Has anyone swapped a complete rear assembly from an S197 into a New Edge?
Curious to what/how much modifications are necessary.
Official member of the anti ethanol-laced gas crusade.
No A/C FTW!
2001 Mustang GT
I'm not sure but I would think it'd be much easier to swap the rear from a sn95 or another new edge seeing as they are all (fox-s197) 8.8 rears anyway...
Sent from not my computer |
you have to set up a panhard bar mounting point on the chasis as well as the upper third mount to the chasis somewhere. No sense in that trouble for an 8.8 when its what comes in our cars
01 GT Conv
I'm curious because there is a Ford Racing, 05-09 complete rear with decent street stuff available for a little over $1200. I like the way my car's rear is set up now and would like to keep it as is for later use. I've just never spent any time under an 05 up chassis and couldn't get an answer on this from Ford.
Not a soul close to where I live with a newer Mustang to crawl under.
its like a pineapple and a kiwi. Nothing even close.
I just listed above what the differences were.
01 GT Conv
Yes, I got it. Just trying to explain why. My original post did come across like a not-so-sensible 8.8 for an 8.8 swap. You know the old saying, "Go by what I'm thinking, not what I'm saying."
2001 Mustang GT
8.98 1/8
Whats wrong with your 8.8?
![]() CHECK MEH GARAGE BAMA Performance Drag Team #9 |
only thing that would work on a new edge is the differential itself. Everything else is different. You can build a rear end for half that cost and be just as strong or stronger
2001 Mustang GT
8.98 1/8
What he said, i got a detroit tru-trac, 3.73 gears , moser 31 spline axles for much less than 1200
My old set up was a truck 8.8 track loc, cobra clutches, us alloy axles. After a few small nick nacks, I think I had 500 bucks in everything, it took a beating for 3yrs and never missed a beat. 1.4 sixty foots off a trans brake, two step and a 100 shot
I did the same thing and even changed gears and I had less than 500 installed. Im still running it 5 years later.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
01 GT Conv
It has a decent gear in it now, but there are times it could use a little more. It's nice and quiet and has strength parts. Combined with swapping complete rears is pretty darn simple with the fact that there is nobody close I would be comfortable with setting up a new gear, I've considered having two assemblys.
What would be perfect is a quick change assembly to switch back and forth. Remember the old Franklins? Maybe a Ford 9 inch, it's almost a quick change. What I need to do is learn proper gear install procedures. I've studied on it many times, just never done it. There certainly would be many trial and errors to learn the little secrets the pros have discovered. It's like everything else----99 ways to do it wrong and one best way to do it right. I need to pick up a cheap, stock complete rear just to do that with.
#13 | |
01 GT Conv
Just looked at your sig video----d**n! That is a wicked sounding machine you have there. Who ported your heads?
Threads Similar to: S197/New Edge Rear Assemby Swap Question
| New Edge wheels on S197 - yay or nay? | JCCNY | 2005 - 2010 | 21 | July 19th, 2011 11:13 AM |
| Just curious: New Edge vs S197 | 99RioGT | 99-04 | 73 | July 21st, 2010 08:46 PM |
| new edge vs s197 v6 exhaust | v606er | V6 Mustangs | 10 | February 25th, 2010 02:06 PM |
| New Edge or S197? | warrior86 | The Clubhouse | 80 | January 14th, 2009 09:51 AM |
