Beyond excited Blowers getting put on thursday - Page 3
Old February 5th, 2012, 11:24 PM   #41
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
The 40amp bap will work with a single pump the same way as the 20amp. With the 40amp you have the ability to go with a dual pump setup in the future and still run your 40amp bap. I have a 40amp that I will be adding to my single svt focus pump.
2003 DSG Mustang GT 5spd
Full Bolt On's, Suspension, Built Rear, V1 S
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60'
Intercooled: 362/370
Old February 5th, 2012, 11:43 PM   #42
MM's most Hated
twinmill's Avatar
2001 Mustang GT
twinmill is infamous around these partstwinmill is infamous around these partstwinmill is infamous around these partstwinmill is infamous around these partstwinmill is infamous around these partstwinmill is infamous around these partstwinmill is infamous around these partstwinmill is infamous around these parts
reps for the info
Yall had me scared for a 2nd, I went with the boost-a-pump instead of the mini race valve.
I was going to be pissed if I couldnt use it
MM's Most Hated
Old February 6th, 2012, 12:15 AM   #43
blownstang's Avatar
I'm doing the bap and vortech mini race with my intercooler install.
Old February 6th, 2012, 01:27 AM   #44
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
Originally Posted by I8ACMRO View Post
Might wanna get a diff fuel pump, as some guys seem to max them out. What's your exhaust like? May wanna open it up. Thought of doing a power pipe? Also, don't forget your TR6 or similar plugs.
Plus one, if he went to a Super car GT pump he could eliminate the need for the BAP and actually save money. The SVT Focus is overrated because it's specs are at 40 psi and not 60 psi.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old February 6th, 2012, 08:39 AM   #45
blownstang's Avatar
The GT pump has not really proven itself to be better. Guys on here running the GT pump are getting the same results as those with an svt pump. There are guys with a single svt pump making 440rwhp. Havent seen the GT pump do any better. Both are almost identical. Some max them out at 380rwhp and others can push mid 400's.
Old February 6th, 2012, 11:03 AM   #46
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
That's what I thought. i bought the Ford gt pump so I didn't have to buy a bap. I maxed my Ford gt pump out at 370rwhp, had to get a bap too.
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old February 6th, 2012, 01:09 PM   #47
MM Official Sammich Maker
roosgt!'s Avatar
1999 mustang gt
n/a
roosgt! is just really niceroosgt! is just really niceroosgt! is just really niceroosgt! is just really niceroosgt! is just really nice
Well there goes my idea of that pump lol.
I just want to run a single pump that i can basically "drop in" and not run a bap.
My search now continues, I'm still leaninfflg towards the stryker pump
KASE Racing
72 Chevell 500hp
74 Comet 500+hp and spray
99 Mustang GT bolt on's and 93 tune
85 Notch 520ci BBF
Old February 6th, 2012, 03:09 PM   #48
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
Did you get genuine Ford parts? The reason I ask is there seems to be a lot of variation in results. It could be that aftermarket replacement pumps just don't perform as well (or maybe its the other way around). I'm running an SVT fuel pump without a BAP and I haven't had any problems.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old February 6th, 2012, 11:56 PM   #49
jivepepper's Avatar
I know the svt is rated a 40 and the gt at 60. I seen the SVT max out on lots of combos when compared to the GT or Aviator pump. I run 2 Aviator pumps ans a bap with stock fuel lines and rails and was only 80% FPDC.
My buddys failed at 420 with a focus pump and a bap.
Threads Similar to: Beyond excited Blowers getting put on thursday
blowers cams pr gt 2005 - 2010 1 May 21st, 2010 10:26 PM
Hurry! Get your Blowers! DarkCandy08GT 2005 - 2010 36 February 6th, 2010 11:05 AM
between blowers? 02gtbangstang General Tech 14 January 23rd, 2008 04:05 PM
chevy 350 blowers itschristorres8 All Other Vehicles 3 October 1st, 2007 08:24 PM
Different types of blowers... BigMike80 2005 - 2010 7 January 8th, 2007 10:45 PM
