MM's most Hated
2001 Mustang GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
Beyond excited Blowers getting put on thursday
Well Im beyond excited now, I woke up yesterday and realized my tax return had been deposited in my bank Act.
First thing I did was visit american muscle's website and order a dual guage pod and a boost guage. Called up procharger afterwards and ordered the oil, hardware kit, and off set spacer I'm either going to have RET or IZZY's Performance tune the car. The set up is Going to be the following P-1sc 3 core intercooler - New style svt focus pump KB 40 amp Boost-a-pump 42lb injectors. 3.6 pully Goodyear gator back 108" belt. I'm wondering what numbers I should expect and be happy with? The car is automatic and has no other mods w/ the exception of LCA's, Springs, Shocks and weld-ins. I am running the stock proflow valve. Will it be ok to wait until march to pick up a vortech mini race valve or is that something I really should order before the tune gets done? I currently have 275 hancock v12s on the back, do you guys believe I should buy a drag radial and run those instead? The v12's are fairly new and have 70% tread left I will have around 500$ left after everything so im trying to figure out another good supporting mod
MM's Most Hated
2003 Mustang GT
14.03@100
Might wanna get a diff fuel pump, as some guys seem to max them out. What's your exhaust like? May wanna open it up. Thought of doing a power pipe? Also, don't forget your TR6 or similar plugs.
MM's most Hated
2001 Mustang GT
Imma run buy autozone and pick up a colder plug at the beginning of the week.
Kit came with what I beleive is a power pipe, hooks up the the front the charger and extends into the fender well with a filter? Do you still think it will max out with the boost a pump? Thats one of the reasons i bought the pump -.-. What numbers should I expect? I was thinking 370-380 rwhp?
MM's Most Hated
2003 Mustang GT
14.03@100
That seems a little low. I'd guess a p1sc with what you have should net you over 400 rwhp. Guys seem to be nutting over the division x pump, or get a GT Supercar pump. If you want more boost though, I'd suggest upping your fuel system now just so it's done.
2001 Mustang GT
12.70@ 113.50
![]() ![]() ![]() iTrader: 3 reviews
You'll be fine with the fuel set-up.
![]() 403rwhp/403rwtq. M.A.D. #11 |
#6 | |
![]() 2003 DSG Mustang GT 5spd Full Bolt On's, Suspension, Built Rear, V1 S N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60' Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60' Intercooled: 362/370 |
Not a chance through the auto and the P1SC. 350-360rwhp is more realistic. Guys with full bolt ons, a 5spd, and 9psi on a P1SC usually put down in the range of 370-390rwhp.
2001 Mustang GT
12.33@111.23mph
I agree blownstang,and not to start a thread war but I always here the procharger dont make power like a vortech? cause im an auto too and I seem to be making just as much if not a tad more power than some manuals here? and im on very conservative timing 12*? i run a v-3 si trim though so who knows?
![]() 2001 Mustang GT - mods+pics in garage, tuned by matt@performance evolution 1996 Civic DX - my dd |
#9 | |
#10 | |
2003 Mustang GT
Yeah your fuel setup is good. The proflow should be fine. Worst case, upgrade it later. Dont need a re-tune. What MAF are you doing?
For power, every car is different. Expect anywhere from 340rwhp to 390rwhp. Depends on type of dyno, air, car itself etc....
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
12.73@111.36
Zinc, aren't you running 12 psi with that 12 degrees of timing and making 366 rwhp? And if your non-intercooled Vortech was running the same IATs as an intercooled ProCharger your tuner would not have had to pull so much timing. The OP will be around 10 psi. Maybe a tad more with the power pipe.
Twinmill, your final results depend upon a lot of things such as supporting mods, tune and correction factor. I'm running 9 psi with a fairly conservative tune. (mods listed in garage).That puts my car around 396 rwhp STD or 383 SAE. If I were running 10 psi it would be at or over 400 (depending upon correction factor). My guess is that you will be around 370-380 rwhp through an auto. (400 / .85 x .80 = 376).
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
MM's most Hated
2001 Mustang GT
Ya I was guessing 380 because of the smaller pully and I had read somewhere the gator belts produce a little bit higher boost due to less belt slipage. Once again I dont know this to be true.
So would headers be more beneficial then nitto555r's ? I ask because I wil be doing runs from a dig and messing around at stoplights ... from time to time.
MM's Most Hated
2003 Mustang GT
Youll see about 10psi with that setup.
Go with 555Rs. Headers are cool, but spinning sucks. Its cute at first because your roasting the tires in 2nd gear, but after a couple days it gets old.
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
yea...roasting tires at 80mph isnt fun lol.
2000 Mustang GT Built 4V Motor with Sullivan Single Plane Intake Custom 66MM BB TT kit Borla XR-1 Dumped before rear Moser built 9" Rear 35 spline WaveTrac Diff with 3.75s 35 spline Moser axles 14PT roll cage and minitubbed
The focus pump and a bap will work just fine for now. The SVT pump will take you to 450rwhp on a stock motor with nothing but boost. Sometimes a little higher on a modded motor with less boost. If you want to get all of it you can out of it PM and I'll give you a list of mods to do when you install the pump that will help.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
#17 | |
In this case you want to be able to put the power to the ground so yes drag radials would be more beneficial, but with stock gearing you won't really be getting much wheel spin. The blower won't be making boost till you get over 3k rpm so you have some time to get moving before the power starts kicking in. See how it feels on your current tires and then get drag radials if you feel they are needed.
#18 | |
2001 Mustang GT
12.33@111.23mph
If you kept the boost at 12psi intercooled and bumped the timing to 15* you'd definitely be over 400rwhp. Probably ~ 415rwhp.
#20 | |
2002 mustang gt
automatic 4.10,s cai 70mm tb plenum udp summit h-pipe hi-flow cats summit catback dynomax race bullets 4inch tips sniper tune tb spacer nitto drag 555r 315/35/17 chrome mach 1 17x9 wheels |
Threads Similar to: Beyond excited Blowers getting put on thursday
| blowers cams | pr gt | 2005 - 2010 | 1 | May 21st, 2010 10:26 PM |
| Hurry! Get your Blowers! | DarkCandy08GT | 2005 - 2010 | 36 | February 6th, 2010 11:05 AM |
| between blowers? | 02gtbangstang | General Tech | 14 | January 23rd, 2008 04:05 PM |
| chevy 350 blowers | itschristorres8 | All Other Vehicles | 3 | October 1st, 2007 08:24 PM |
| Different types of blowers... | BigMike80 | 2005 - 2010 | 7 | January 8th, 2007 10:45 PM |
