#21 |
2001 Mustang GT
34.82 @ 21
![]() ![]() iTrader: 4 reviews
'01 GT - T56 6 Speed - Centerforce DFX - SCT LiveWire - Borla Stingers - Magnaflow Catted X - Steeda Tri Ax - Cobra Aluminum Driveshaft - 3.73s - Eibach Pro-Kit - MM Full Length Subframe Connectors - MM Caster Camber Plates Vortech V1 sold |
#22 |
02 Mustang GT
9.91@133
I figure the car will make the same hp with 6-7lbs less boost.
I've got a fresh set of ported heads with new guides, valves and high load comp valve springs. They are ported a lot more than the heads I just removed. I also just had my edelbrock intake ported. Removed head. ![]() My "stock" PI heads that came with the car when I bought in in 02 with 17 miles. ![]() ![]() ![]() ![]() ![]()
2002 GT PI heads Twin 60mm turbos Th400 6.34@114 1/8 9.99@137 1/4 http://i160.photobucket.com/albums/t...t/DSCF5654.jpg http://i160.photobucket.com/albums/t...2gt/IMG060.jpg |
#23 |
What rear end gear are you running? Your still running a th400?
#24 |
02 Mustang GT
9.91@133
3.27 gears...Yes, still running a TH400.
#25 |
02 Mustang GT
9.91@133
Rod bearing came in today, so worked on it a little while.
My ring filler. ![]() ![]()
#26 |
I like boobs!!!
2000 GT convertible
dunno
How can you run that much lift on a PI head with flat tops and no PTV issues? Mind = Blown
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
#27 |
02 Mustang GT
9.91@133
Well, I found out my block has a broken head bold in one hole. It's not very easy or cheap to get it out. So, I bought some new custom 3.7 bore flattop pistons for my darton wet sleeved bigbore teksid block. I dropped off everything at the machine shop today. The new pistons..
![]() If anyone is interested I will sell the rotating assembly in this thread for $1100 shipped.
#28 |
02 Mustang GT
9.91@133
I drilled out the broken head bolt and installed a time sert. Then as I was torquing the last arp head stud to 90lbs it snapped. So, I drilled it out and installed a time sert in that hole. It didnt hold when I torqued it to 90lbs. It pulled the insert out.
Thought I was screwed at that point. I then bought a 18" section of 1/2" all thread. I drilled and tapped the hole for the 1/2" all thread. I then drilled and tapped the All thread for 11mm 1.5 thread, which is the size of stock threads. It held and the engine is built and I plan to drop it in tomorrow. My home made insert.. ![]()
#29 |
Gotta say I admire your desire to make things work.... I would have done something of the same. Nothing worse than getting all the way through a build and realizing you gotta start over!! I just did it with my 4.6 then upon reassembly it peeled a thread in the connecting rod. Had to pull the rod, buy a new H beam and now its back together. What a bitch. Been a pain the whole way!
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
Threads Similar to: Building high compression engine
| High compression help | jme30426 | 96-98 | 34 | October 7th, 2011 10:26 AM |
| Thoughts on building a high compression E85 motor | Petty886596 | 5.0 Mustangs | 1 | December 6th, 2010 06:54 PM |
| High Compression for S/C? | SUHLeen | 2005 - 2010 | 1 | June 2nd, 2009 09:57 PM |
| High vs. Low Compression | 87StangLX | General Tech | 14 | November 17th, 2007 10:42 PM |
| Building a 89 GT in High School | Darrellx14 | 5.0 Mustangs | 16 | July 28th, 2006 11:17 AM |
