02 Mustang GT
9.91@133
Building high compression engine
Yes I pretty much do all my own work. This is the build of my new shortblock. I pulled the engine that was running just fine and pushing my car into the 9's without 1200rwhp just to swap in some flattop pistons to really bump up the compression. My machine shop checked out my block and said it really needed to be bore a little. I already had the pistons I planned to use. So, I took them a fresh untouched teksid block. I went and picked it up along with the rotating assembly that was balanced.
2002 GT PI heads Twin 60mm turbos Th400 6.34@114 1/8 9.99@137 1/4 http://i160.photobucket.com/albums/t...t/DSCF5654.jpg http://i160.photobucket.com/albums/t...2gt/IMG060.jpg |
MM's king of Neon's
404 - car not found
17.81@87
Damn, flattops? That's got to put you in the 11:1 CR range.
What are you running for fuel? Going E85 for it?
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
02 Mustang GT
9.91@133
Been running E85 for 2 years now. It will be closer to 12:1. I was running 9.4:1.
1997 Pacific Green Cobra
14.80 No traction
haha awesome. were almost doing the same thing huh. What brand rotating assembly you using Im going with a set of custom grind cams more than likely. im looking for a good 7500 rpm
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
02 Mustang GT
9.91@133
I'm using a forged cobra crankshaft and manley H-beam rods with arp 2000 bolts.
My cams are 232/230 .560/.560 with a 115lsa.
99 limited edition vert
you will be pleased with what high cr and boost will give you, running c16 or methanol. running 32 psi at 12.5 cr on methanol and 572ci with shorties makes a wonderfull crackle lol
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
14.80 No traction
GEE sus. thats some nasty lift. Can't wait to see it run. ui expect to be done mine in about 8-9 months.
02 Mustang GT
9.91@133
Mine will be running in under two weeks.
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Appoved man! Can't wait to see the spool difference
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
upping the size of turbo's?
02 Mustang GT
9.91@133
No, the 60's will support 1100fwhp and I don't plan to max them out. I figure the car should have no issue running deep 9's.
Scott, spooling was not an issue before. I'm sure they will spool even quicker.
BYAHHHH!
2001 Mustang GT
13.874
Spool so much faster
1999 Mustang GT
Will you have to notch the piston? I built my engine with 10:1 pistons and was just wondering how much cam you can do before notching for the valves.
02 Mustang GT
9.91@133
No notches needed.
1999 Mustang GT
Good to know, thanks man! Looking forward to following this build.
02 Mustang GT
9.91@133
Now I just need to file the rings. I've been waiting on rod bearings since 12/29/2011...
I may have to buy another set local to speed up my assembly.
11.463@121.50
How much boost will you be throwing at it?
MM Bracket Racing Crew Member #5 |
Daily Driven
So just a compression bump? No other changes ? I`m pretty sure i remember reading you street tune the car so i know we wont see dyno numbers of the diff the bump in compression made.
Looking forward to seeing some track times to see how much the bump in compression made
Tuned by http://www.brooksspeed.com/ 2001 TB Turbo Bullitt 520 RWHP @ 8lbs on a Mustang Dyno |
2003 Mustang GT
12.28 @ 116
![]() ![]() iTrader: 13 reviews
Very nice man
![]() 2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's |
Threads Similar to: Building high compression engine
| High compression help | jme30426 | 96-98 | 34 | October 7th, 2011 10:26 AM |
| Thoughts on building a high compression E85 motor | Petty886596 | 5.0 Mustangs | 1 | December 6th, 2010 06:54 PM |
| High Compression for S/C? | SUHLeen | 2005 - 2010 | 1 | June 2nd, 2009 09:57 PM |
| High vs. Low Compression | 87StangLX | General Tech | 14 | November 17th, 2007 10:42 PM |
| Building a 89 GT in High School | Darrellx14 | 5.0 Mustangs | 16 | July 28th, 2006 11:17 AM |
