1996 Mustang 3.8l
Boosting #'s
Were running on a forged Windsor block, port and polished big valve heads from dss, stroked forged steel internals (5.0) and everything blueprinted from dss. We have the typhoon intake and a high flow upper plenum. What I'm wondering is how much boost could this thing hold as a weekend warrior ?
![]() 96 v6 - needs v8 03 Roush - needs turbo 06 F250 6.0 - needs stepladder |
2000 gt
you spent a bunch of money, and ended up with a typhoon intake? get rid of that and get an edelbrock. other than that everything else looks good.
what fuel set up do you have in the car? or what are you planning on? what crank is in it, forged or stock cast crank? what pistons/rods? there's alot of variables but if the parts are right you can throw 18 lbs at it, do that with cheapo forged rods/pistons and you're in trouble lol.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
1996 Mustang 3.8l
Crank is forged cobra 3.543, pistons are forged pro-x #4610, rods are 4340 forged 5.933 full floating hbeams with arp 2000 bolts
2000 gt
i'd want to start at 14 lbs and climb my way up. also depends on if it's going to be intercooled or not.
1996 Mustang 3.8l
Plan on being intercooled. I'm just kind of looking for a top number. Dss told us in 2006 when we bought it that they would warranty 15 lb boost
1996 Mustang 3.8l
We bought all this back in 2006. Back then we spent around 10k
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
What cc are your pistons. Figure out your dynamic compression as well. Fuel system is probably your weak link.
Wallace Racing: Dynamic Compression Ratio Calculator
![]() bone stock from the factory! |
1996 Mustang 3.8l
Compression is 9.5:1 and it has 42# injectors and she has flat top pistons 10cc
99 limited edition vert
If the stroke is 3.543 then it is not stroked. your not 5.0 unless you have a 3.7 bore
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
2003 mustang v6 ;)
slow
Still kind of missing some info. You say 9.5-1cr but you have -10cc pistons. Is your motor a 4v? Cause if it is a 2v with 42cc chambers your closer to 10.5 - 1
1996 Mustang 3.8l
It might be 10.5. Its been since 2006 since we built this thing lol
1996 Mustang 3.8l
The paperwork on it from dss says the pistons are max quench 10 cc. She is also bored .20"
If everything is forged I see no reason why you wouldn't be able to push 20psi through it if your compression is in fact 9.5:1. If it's 10.5:1 then you may want to run less boost. Your 42lb injectors are going to be the weak link. 42's are usually good to just over 500rwhp.
![]() 2003 DSG Mustang GT 5spd Full Bolt On's, Suspension, Built Rear, V1 S N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60' Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60' Intercooled: 362/370 |
1996 Mustang 3.8l
What # injectors would be good for say. 15 lbs on the current setup
00 Mustang GT Vert/88 5.0
60lb injectors is what i recomend, but if your compression is 10:1 I would push the boost much past 15-16PSI. why the high compression on a supercharged engine build?
![]() Proud Iraq and Afghanistan War veteran Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
02 Mustang GT
9.91@133
80lb injectors are about the same price and are what I run. Your engine will handle what ever boost you want if you have the fuel and tune to keep up.
2002 GT PI heads Twin 60mm turbos Th400 6.34@114 1/8 9.99@137 1/4 http://i160.photobucket.com/albums/t...t/DSCF5654.jpg http://i160.photobucket.com/albums/t...2gt/IMG060.jpg |
2000 gt
i'd go 60's, and a dual pump set up. if your compression is that high (10.5/1) i'd keep it around 12-13 lbs personally. much higher and you risk detonation. forged or not pistons/rods don't like detonation lol.
1996 Mustang 3.8l
I was actually thinking turbo. And my dad swears that they changed the compression numbers down to 9.5:1. The main thing I remember about that engine is that they cut a water jet to thick and it caused a major waterleak. So they replaced the head.
2003 mustang v6 ;)
slow
im pretty sure by your build sheet the 10cc dish wont net you under 10 - 1 cr, unless they really worked out the combustion chamber and tossed a thick head gasket in, but that would be alot of work for someone to do when all you needed was a proper dish piston.
1996 Mustang 3.8l
I just was contacted back from DSS. They were able to tell me that the engine infact has dish pistons and not flattop. they also say that it makes 9.7:1 and possibly a little less if the pistons are below the deck.. So just to see what to look forward to.. how much boost and how much hp/tq should I be looking for if its tuned right?
Threads Similar to: Boosting #'s
| Is boosting in 5th bad and why? | 03OFP | 99-04 | 37 | June 23rd, 2011 01:23 PM |
| Boosting the '12 | slagburn | 2011+ | 16 | May 10th, 2011 03:32 PM |
| Boosting Your v6 | ESG-642T | V6 Mustangs | 41 | June 28th, 2010 05:34 PM |
| boosting in fifth? | redrocket | 99-04 | 117 | May 3rd, 2010 07:52 PM |
| boosting hp in a 200 c.i. 66 | 66coupe | Classic Mustangs | 30 | September 2nd, 2007 03:05 PM |
