Intake Manifold Leaking
Hey guys, I noticed I was a bit low on coolant today, looked around and saw the area around my thermostat (between stat and spark plug) was damp. I assume I need a new intake manifold as mine is warped? How are the Dorman replacements compared to OEM? Also roughly how much are new gaskets? as I assume the new Intake Manifold won't come with them?
Is it possible that this could cause bad fuel economy? I have always gotten bad MPG, and I don't drive hard/car is all stock. I'm thinking if this is warped perhaps the intake port right beside the thermostat area could be drawing in un-metered air? I get about 250miles/tank, 80% highway. car has 140,000miles -2002 Mustang GT |
2000 Mustang GT 5spd
35.9@16.99
![]() ![]() ![]() iTrader: 17 reviews
Don't get dorman.
Get the ford racing one off AM for. 169.00.
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html |
I just ordered the one from American Muscle!!! Is there anything I should know when I install, or is it straight forward?
Do I need a new throttle body/plenum gasket? Also the new one doesn't come with intake manifold gaskets does it? |
1997 Pacific Green Cobra
14.80 No traction
Probably not. did you check to see that the T stat itself was not leaking ?
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
i checked the t-stat and no leaks there, just where the aluminum meets the plastic you can see it's wet, but it's not pissing out which is good.
#6 | |
35.9@16.99
The intake has gasket on it. You'll need the intake manifold gasket from ford. Write up i made Intake Manifold Removal/Reinstall
#7 | |
35.9@16.99
awesome write-up, thanks!!!
#9 | |
12.73@111.36
P.S. You cannot measure fuel usage by the tank. You need to measure it by the gallon.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
#10 | |
00 Mustang GT Vert/88 5.0
Did you check to see if your bolt might have came loose? that would be my first move before I went ordering a new intake.
![]() Proud Iraq and Afghanistan War veteran Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
Threads Similar to: Intake Manifold Leaking
| Intake Manifold Swapped... AIR LEAKING? HELP | bebo109 | 99-04 | 3 | December 4th, 2010 02:45 PM |
| Leaking Manifold | 00_mustang_v6 | V6 Mustangs | 6 | September 28th, 2010 12:41 PM |
| Non PI intake manifold vs Aluminium crossover Intake manifold | cedp83 | 99-04 | 1 | September 9th, 2010 02:04 AM |
| Well the intake manifold started leaking | Nossit | 99-04 | 0 | June 2nd, 2010 01:12 PM |
| water crossover on intake manifold leaking coolant | hardhitter | 99-04 | 10 | January 5th, 2009 02:39 AM |
