EVO LVR
2003 Mustang GT
.3 @ 246927429243
TERRIBLE Gas Mileage
So lately I've been getting around 80-100 miles on basically a full tank. I have no idea what's wrong with it. It does feel sluggish, so I'm thinking it could be clogged cats?
I did an maf test, and when I unplugged it, my car still idled so it could be bad too. Is there anyway to test if you have clogged cats without taking it to a dealer or shop? Thanks. |
EVO LVR
2003 Mustang GT
.3 @ 246927429243
I have also started to hear a ticking sound when idling, possible exhaust leak?
1997 Pacific Green Cobra
14.80 No traction
Check the oxygen sensors. sounds like you are dumping fuel. I mean basic things to check are
O2 sensors Wires Plugs Sensors. How does the ticking sound ?
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
Is the CEL on?
2004 Mustang GT 40th Aniv 5spd, Stock for now. 2005 Joe Gibbs Silverado #0396 1986 Monte Carlo SS |
#6 | |
EVO LVR
2003 Mustang GT
.3 @ 246927429243
Sent from my dog. |
EVO LVR
2003 Mustang GT
.3 @ 246927429243
14.80 No traction
Pick up two motor craft O2 sensors from rockauto.com. OEM are best and they have them dirt cheap.
Forgot that you have COP so it should not be an issue unless you are getting am misfire. Plugs should just be changed and gaped if you never did before. its easy to do.
EVO LVR
2003 Mustang GT
.3 @ 246927429243
Changed the plugs not too long ago and they were gaped.
12.73@111.36
My best guess is clogged cats. I had a Chevy truck that had clogged cats. It is surprising how much fuel the computer will pump into the motor when that happens.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
EVO LVR
2003 Mustang GT
.3 @ 246927429243
Anyway to check to make sure its clogged cats? Might just call the dealership tomorrow and have them look.
Traction...?
1996 GT/ 2008 GT Vert
Unbolt your mid pipe from your cat back. Hit each cat with a rubber mallet, usually you can hear some clunking and what not.
EVO LVR
2003 Mustang GT
.3 @ 246927429243
Still getting terrible gas mileage. Haven't had time to check any of this lately though. Been really busy. I average around 60-70 miles on 3/4ths tank... It's that bad. I'm gonna call the dealership and tell them that I'm getting bad gas mileage and need them to look at it. I hope I can find out whats wrong, really annoying have to put $20 in this damn car every week just to drive to school and back.
2000 Mustang GT 5spd
35.9@16.99
![]() ![]() ![]() iTrader: 17 reviews
Take it to an exhaust shop. They will drill a hole, and test it. Shop did mine for. 10.002-4psi is what they said it has to be around.
If you have an exhaust leak, I'd bet it's a o2 problem. When I had a exhaust leak I'd suck gas out. I put quiksteel around the leak and sealed it. Got better mpg too.
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html |
2003 Mustang GT
I was curious to see how much gas I got out of a full tank. It was at about 180 miles at 1/8 of a tank. Don't know if thatw good for my set up?
Op, probably needs a tune up. Replace the fuel filter, air filter, spark plugs. Check the rear o2s. Clogged cats usually give a bad odor, so if you don't smell it chances are their fine. MAF isn't bad. Car can run without the maf plugged in, it'll just rely on the front o2 sensors basically.
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
EVO LVR
2003 Mustang GT
.3 @ 246927429243
Thanks Shaun. Replaced the air filter, and spark plugs already. I'll check my fuel filter tomorrow and see how dirty it is and probably go get a new one. Reccomended brands?
meh
If the catalytic converter(s) is/are blocked, you probably wouldn't even get a code.
If you're not getting a code, other stuff like your O2 sensors are probably good. The computer checks for issues with them constantly... if one of them isn't reporting acceptable measurements (which it wouldn't if it were defective), you will get a code for it. For cats, they can fail in a few different ways. First, you should know they are essentially a can with a honeycomb shaped catalyst (usually an alloy containing platinum) inside, which is wrapped with a fiberglass insulation so it wont rattle inside the can. If the fiberglass burns out, the cat will rattle loudly. It will not effect runability or fuel economy in any way. You will probably get a code, because the raw exhaust is going around the catalyst (honeycomb platinum part) without being burned, and the O2 after the cat is detecting the raw exhaust gasses. If the catalyst honeycomb breaks apart and turns sideways, it will create an effective air block, and will also hinder performance. It will probably rattle like hell, because at this point there are chunks of metal rolling around inside the "can." You will probably get a code here too, because exhaust gasses are going around the catalyst instead of going through it. ![]() If you have mechanical engine issues, the cat could clog up with oil/other crap, which could keep it from working correctly. Again, this would probably throw a code. Or, if it gets super hot, it could melt itself shut. ![]() In that case, you probably wouldn't get a code, at least not for the cat. Because technically, the cat is still working... at least part of it is. The exhaust gasses still go through the open part of the cat, and is cleaned up, so the O2 sensor after the cat would detect clean exhaust, and wouldn't throw a code. But, with so little exhaust flow, it would run like shit.
'87 2.3 Notch with +4 cylinder mod ![]() Ass, Cash, or Grass.. nobody rides for free Black Stang Crew Member #11 |
Threads Similar to: TERRIBLE Gas Mileage
| Terrible Day... Just Terrible | zinc02GT | The Clubhouse | 18 | December 27th, 2011 11:11 PM |
| Zip is a terrible terrible person! | Arsenal | The Clubhouse | 40 | December 16th, 2010 07:42 AM |
| This is terrible | 98FireyGT! | The Clubhouse | 1 | December 29th, 2009 08:51 AM |
| Not Bad, Terrible MPG | blazor | V6 Mustangs | 40 | March 30th, 2008 11:35 AM |
