2000 GT
N/A
Do I need to reset my speedo?
First, please don't bite my head off for not using the search because I did but I was getting all kinda of confused from all the things being said.
I just got some 17x10.5 bullitts with 315-35-17 555r's the front are still 245-24-17. Do I need to recalibrate the speedo for these? I've heard yes and I've heard no because it's still the same overall or something and I've heard it needs to be set according to the rear tires only and I've heard to average the front and rear size for what to set it at. So if anyone can shed some light on this for me that would be great. Also I have an sct live wire with the free tunes through am. Can I reset the speedo through that or do I need them to write me a new tune? |
2003 ford mustang gt
13.9 stock
you can put in the tire info on there tune sheet of whats done to your car
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
2000 GT
N/A
Ok I'll do that I was just hoping it was something I could do myself because it takes a few days for them to do everything and I just got a new tune for all my stuff haha but thanks.
Look up information before giving advice... You need to do NOTHING, 245/45-17 and 315/35-17 are BOTH 25.7in in diameter... So you are fine and do not need to calibrate your speedo...
Tire size calculator
2004 Mustang GT 40th Aniv 5spd, Stock for now. 2005 Joe Gibbs Silverado #0396 1986 Monte Carlo SS |
^+1, they have the same OD--no change of anything is needed...
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
2000 GT
N/A
Yea that's what I thought thanks guys
12.73@111.36
N20zuki is correct. The tires have exactly the same diameter. If you have further questions you can use the tire size calculator:
Tire Size Calculator - tire & wheel plus sizing
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
Threads Similar to: Do I need to reset my speedo?
| Today I reset my ECU | Xzavier247 | V6 Mustangs | 21 | December 4th, 2011 12:42 AM |
| gauge reset mod. | Maverick530 | 99-04 | 23 | December 10th, 2010 10:44 PM |
| reset the ecu | walt1120 | V6 Mustangs | 4 | June 9th, 2010 12:44 AM |
| Odometer reset? | Infamous_GT | 99-04 | 4 | May 9th, 2010 04:02 PM |
| How Do I Reset My Ecu?!?! | Youngstang57 | 2005 - 2010 | 3 | December 8th, 2008 12:39 PM |
