Custom air intake for procharger...
Old February 5th, 2012, 09:12 PM   #1
sjac9999 is on a distinguished road
Hey guys, I'm haveing clearence issues with my procharger air intake the filter keeps getting crushed, plus I want a bigger piped intake, post pics and info on how you made your own... Thanks guyZ
Old February 5th, 2012, 09:49 PM   #2
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
i didn't custom make one but if you google it neverenuff has a writeup over on modulardepot's forums for one he made years ago.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old February 5th, 2012, 10:18 PM   #3
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
What is it getting crushed against? The Anderson power pipe puts the air filter in the fender well. You have to cut a bigger hole in the inner fender to get it there. It may be a tight fit and I have scrapped it taking it out and putting it back in, but I haven't crushed my air filter. Here's a pic.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old February 5th, 2012, 10:21 PM   #4
2000 gt
i have an anderson powerpipe on my car, i should have posted that. some people on here will say a procharger does not need a new powerpipe, but i think i picked up a lb of boost with it.
HARDCORE CREW
Old February 5th, 2012, 10:56 PM   #5
Chris747's Avatar
2003 GT
Chris747 will become famous soon enoughChris747 will become famous soon enough
The problem I have with the procharger intake pipe is if I drive it in the rain it seems to suck water if its raining hard enough, and that causes the car to bog down.
2003 DSG GT ... P1SC, MGW Shifter, NTO5 295 Rear Tire, H&R SS, MAC Long Tube Headers and Prochamber, Flow masters, 3.73 Gear, Blowe Cams, Tuned by Bob Kurgan
My Build Thread
Old February 5th, 2012, 11:01 PM   #6
12.73@111.36
Would you post pictures? With the intake at the top of the radiator that is not impossible but unlikely. I have sucked water through my entire system and fowled the MAF which is located after the intercooler. But the water was so deep it came into the cab through the door panels and soaked the carpet.
Old February 5th, 2012, 11:05 PM   #7
Chris747's Avatar
2003 GT
Mine is the same as yours you pictured above. My car is currently out of commission Due to MAF problems as well. The Bogging down thing has happened on more than one occasion as well after a heavy rain.
My Build Thread
Old February 5th, 2012, 11:26 PM   #8
MM Official Sammich Maker
roosgt!'s Avatar
1999 mustang gt
n/a
roosgt! is just really niceroosgt! is just really niceroosgt! is just really niceroosgt! is just really niceroosgt! is just really nice
Will you notice much of a difference from tucking the powerpie in the fender compared to it sitting in the engine bay?
KASE Racing
72 Chevell 500hp
74 Comet 500+hp and spray
99 Mustang GT bolt on's and 93 tune
85 Notch 520ci BBF
Old February 6th, 2012, 12:00 AM   #9
I think where it mounts to the head unit is outta wack and the filter gets crushed in the hole that leads to the fender, I was wanted something with better air flow... The Anderson power pipe is exactly what I was gonna attempt to make haha
Old February 6th, 2012, 12:02 AM   #10
Chris747's Avatar
2003 GT
this may help..
parts list to make your own power pipe.
My Build Thread
Old February 6th, 2012, 12:11 AM   #11
this may help..
Awesome! Much cheaper than the Anderson kit! Thanks!
Old February 6th, 2012, 12:44 AM   #12
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
your welcome sjac9999, btw moving the filter in the fender does leave you with some cutting of the fender since procharger has the ic pipe running threw the same hole. also fender mounted filters does reduce intake temps but leaves your filter to get dirty faster and rain water will get sucked up if your not careful.
bone stock from the factory!
Old February 6th, 2012, 08:32 AM   #13
03OFP's Avatar
2004 Mustang Gt
Unknown
03OFP is on a distinguished road
Anderson Powerpipe FTW.
04 GT, Vortech V-3, Hi-Tech Stage 2 Cams, BBK shorties, ProChamber mids, SLP LM1's, FRPP aluminum D/S and 3.73's, Acufab upper plenum, 75mm TB, 75lb/hr FIC injectors
Threads Similar to: Custom air intake for procharger...
procharger custom tubing request? mustanginky 99-04 2 September 20th, 2011 10:41 PM
Custom intake piping UnixHH 99-04 20 June 6th, 2011 09:52 PM
help with custom intake scp616 99-04 1 May 15th, 2010 11:19 PM
procharger custom power pipe mustanginky General Tech 15 April 28th, 2009 08:03 PM
Custom Intake Manifolds? via sin dios V6 Mustangs 6 January 8th, 2007 11:05 PM
