2001 mustang gt
12.89@104
![]() iTrader: 1 reviews
Wiring my BAP?
Okay so I tried to read up on the web and instructions on installing my bap. First off I didn't know it had a vacuum activation line. But I did read that most do not use it. If I choose not to use it, what activates it? It's seems like an easy install, but I just wonder how you guys are putting them in. Where are you guys putting the control switch, also?
2003 Mustang GT
Yeah its pretty simple.
Take the loom off the fpdm wiring. And cut the pink wire with black stripe about 6" down. Take the fused red wire from the bap, solder it to the pink wire going IN to the fpdm. The other red wire from the bap, solder that to the other piece of the pink with black stripe wire that you cut. Black is obviously ground. Then for a switch, I have a dial. I believe it reads 0-50 rich and lean. I cant remember. Then its just like an auxillary cable that goes into that, and all done.
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
the wires going to the hobs switch need to be tied together. this way the bap is activated. as for the ajustment dial, i would cut those wires and tie them together as well. once your car is tuned you wont mess with it, and leaving it running full time all the time for the fpdm is the proper way to wire the bap for returnless.
![]() bone stock from the factory! |
2001 mustang gt
12.89@104
That's perfect guys!!!! Thanks a lot!
Oh, what about the vacuum line? I don't have it in front of me, sooo, is it already hooked to the bap? If so what to do with it |
2003 mustang v6 ;)
slow
no the vacuum line hooks into the hobs switch, then the long wire lume with bare ends connets to the hobs switch. you need to loop those wires together so you dont need to run a hobs switch.
If you wire pre FPDM you eliminate the Hobbs/boost switch and run the powerall the way up. The CPU will control the power going to the BAP. If it sees to little or to much it will correct by sending less or more to the FPDM which also means less power to BAP. That way you can use all the power from the BAP if needed. Plus the Hobbs switch cause hard offs and on's which can cause stumbling and missing.
I also reccomend a 10 gauge wire upgrade with a 40 amp relay.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
2001 mustang gt
12.89@104
Oh, oh, got It. Thanks!!!!!
12.9 @ 111.44
Seems pretty easy, better to do by ones self or have a shop install?
![]() l Custom Hotside l TurboSmart l MHS l Hallman l On3 l BBK l Hellion l SCT l Flowmaster l Steeda l AEM l Tial l HPX l Hawk l Trickflow |
2003 mustang v6 ;)
slow
it is easy do it your self
Threads Similar to: Wiring my BAP?
| NX Wiring | FastestGTAround | 99-04 | 0 | July 11th, 2010 04:36 PM |
| How to convert from a H3 bulb wiring to 893 bulb wiring? | natedawgishot | V6 Mustangs | 0 | February 2nd, 2008 12:04 AM |
| N/A wiring to turbo wiring | 78mach1 | 2.3 Mustangs | 2 | January 22nd, 2008 08:03 PM |
| wiring help | 95 mustangmiz | Audio/Video | 1 | June 16th, 2007 12:19 PM |
| wiring???? | 95 mustangmiz | Audio/Video | 1 | June 16th, 2007 12:01 PM |
