Transmission Cooler Recommendations
Old February 6th, 2012, 01:28 AM   #1
Jackson4308 is on a distinguished road
Hey everyone! I was wondering what transmission coolers you guys recommend. I have an 02 GT. I'm also looking at buying a trans temp gauge. What tranny coolers and what brand of gauges do you guys recommend? Thanks in advance.
Old February 6th, 2012, 01:37 AM   #2
1986 Mustang GT
Striker is on a distinguished road
Any trans cooler will work and I would go with a name brand gauge for any and all of them you wish to change or add. The auto parts store brand gauges can work good but not any that I have had. I have to buy my third temp gauge thanks to oriley. So I would not recommend them. I can not even tell u what my temp is anymore. It was always on the cold side. Now it dont work at all.
Old February 6th, 2012, 01:40 AM   #3
Alright thanks man. I've been looking at a few brands of gauges. Mainly Auto Meter and Pro Comp.
Old February 6th, 2012, 01:49 AM   #4
Gotboost is on a distinguished road
I would recommend that when you do run your cooler you run it from it from your transmission to the factory cooler in the radiator and then into your transmission cooler. This helps bring your trans temp up to operating temp and allowing the lock up on your transmission to work properly, if not when cold your lock up will not work properly.... I also installed a inline temp gauge port between the trans cooler feeding the transmission.... As far as a cooler goes I bought the biggest bar and plate cooler that also came with a fan on it from jegs(jegs brand)
Old February 6th, 2012, 04:43 AM   #5
CobraStang161's Avatar
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
CobraStang161 will become famous soon enoughCobraStang161 will become famous soon enough
Go with a B&M cooler. They are the best tranny coolers out there. Have one for my 4r70w that sees over 1000hp.
Built 4V Motor with Sullivan Single Plane Intake
Custom 66MM BB TT kit
Borla XR-1 Dumped before rear
Moser built 9" Rear
35 spline WaveTrac Diff with 3.75s
35 spline Moser axles
14PT roll cage and minitubbed
Old February 6th, 2012, 05:33 AM   #6
2002 mustang gt
momogt is an unknown quantity at this point
got me a b&m 70264
automatic 4.10,s cai 70mm tb plenum udp summit h-pipe hi-flow cats summit catback dynomax race bullets 4inch tips sniper tune tb spacer nitto drag 555r 315/35/17 chrome mach 1 17x9 wheels
Old February 6th, 2012, 08:19 AM   #7
andrewskaggs's Avatar
2003 Mustang GT
8.26@83.06 (1/8)
andrewskaggs has a spectacular aura aboutandrewskaggs has a spectacular aura aboutandrewskaggs has a spectacular aura about
What size did you put in your car? I've got to order a cooler in the next couple of days as well. Do you have a transbrake in your 4r? What's the stall on your converter?
I have no idea how to compare the heat generated from your 4r lockup converter and my non-locking c4 converter...just trying to get an idea how much heat you're generating.
SLP :: SCT :: Eaton :: Maximum Motorsports :: Baseline Suspensions :: Strange Engineering
MM Bracket Racing Crew
BAMA Performance Drag Team #1
Project Thread :: YouTube Channel
Threads Similar to: Transmission Cooler Recommendations
Transmission Cooler? Mr. Zip V6 Mustangs 13 June 15th, 2009 07:16 PM
transmission cooler anyone? ajm 99-04 10 March 8th, 2009 11:50 PM
Transmission Cooler? RX Bandit 2005 - 2010 0 March 18th, 2008 01:08 AM
Transmission Cooler poisonstallion95gt 94-95 5 November 3rd, 2007 04:21 AM
Transmission Oil cooler Mustang Mike 99-04 1 March 5th, 2007 09:41 AM
