2001 Mustang GT
9.30 @ 77mph-1/8th mile 2.2 60'
![]() iTrader: 3 reviews
fastest way to change oil pan?
im guesing drop the k member? ive read many times it doesnt take long. i have an engiine hoist. would dropping the k give me full acess to the oil pan? i just wanna swap pans quick and see if thats where my noise is coming from in my engine
01 GT. 5spd , 03-04 cobra clutch, on its 2nd 4.6l motor 2nd tr3650 too,JLT CAI,UPR o/r x, magnapack catback, predator tuned, H&R ss 10.5" bullitts w/ nt555r DR's
2003 Mustang Fauxbra
N/T @ Fast
Yep, drop the K. Full access.
![]() All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now? 03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold |
April 2012 ROTM
yep...drop the k
![]() do yourself a favor and use a bar across the shock towers to hold up the motor...that way the legs of the cherry picker arent in your way. Also, on the gasket, they are reusable but some locktite gasket eliminator (#515 I think, the clear puprple stuff) real thin never hurts and itls never seep much less leak
True blue crew founder/member #1378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer |
12.9 @ 111.44
If you think there's a noise coming from the bottom of the engine I think you can just put your head down there, is dropping the k and swapping a pan really necessary
![]() l Custom Hotside l TurboSmart l MHS l Hallman l On3 l BBK l Hellion l SCT l Flowmaster l Steeda l AEM l Tial l HPX l Hawk l Trickflow |
2001 Mustang GT
im almost 100 percent sure the fins are hitting in the pan. hitting the rod caps and countershaft weight or whatever on the crank
2001 Mustang GT
i could feel it hittin the pan when i put my hand on it as it was running
2001 Mustang GT
I'll be dropping the k this week. Are there any write ups besides zincs! Nothing against his, I just want more info and opinions on things
I might be doing this myself, as my oil pan gasket is leaking (or rear main) I have oil towards the back of the oil pan. How hard is it to drop the K-Member?
99 limited edition vert
add 1 gal of gas in oil fill cap. wait 30 secs then follow with match. presto... pan is off
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
#10 | |
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
2000 Mustang GT Built 4V Motor with Sullivan Single Plane Intake Custom 66MM BB TT kit Borla XR-1 Dumped before rear Moser built 9" Rear 35 spline WaveTrac Diff with 3.75s 35 spline Moser axles 14PT roll cage and minitubbed
2001 Mustang GT
Lol.
April 2012 ROTM
I lol'd
dropping the k member is easy as hell..you wont have any problems. If you dowel pin the back two tabs in to the subframe then it'l go back in right where it came from smooth as butter
2001 Mustang GT
Good tip!
04 mustang gt
7.21 @ 98
hold the engine up with a hoist or the tool. unbolt the steering shaft and rack bolts. remove tie rod ends from spindle. pry the rack off (i just let mine hang). remove brakes and remove bottom strut bolts. remove ball joint nut and remove spindle. remove motor mount nuts. then 8 bolts and it should be down unless i forgot something. thats the basics anyway
![]() cams + 150 shot |
#15 | |
April 2012 ROTM
just my .02.....
04 mustang gt
7.21 @ 98
i just let the rack and calipers hang lol
your right though, no need to remove the spindles...i was thinking of when i dropped mine to install the tubular k/a-arms so i had to remove them
April 2012 ROTM
I was wondering why you opted to take them off haha
2001 Mustang GT
is there pics somewhere of how and where to drill holes for these dowels?
2001 Mustang GT
is the k member bolted to the frame inside the wheel well? sorry for the stupid questions. havent been around the car for a while and never really studied how the k member is held in
N/T @ Fast
Two bolts in the top spring perch, two at the rear of the K on each side for a total of 8. I dont remove the rack unless im swapping Ks. Remove wheels and calipers then zip the top strut nut off and lower the a arm with a jack. Slide the K forward and you'll have plenty of room. The leak towards the back is either the rear main or the rear main retainer plate. Replace to rear main after removal/cleaning/resealing the retainer plate(it doesnt use a gasket).
I failed to mention the two nuts that secure the motor mounts to the K.
![]() All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now? 03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold Last edited by bulloch27; February 7th, 2012 at 03:36 PM. |
Threads Similar to: fastest way to change oil pan?
| Color change me and change my wheels... PLZ | RZNCAIN | Chopshop | 26 | August 19th, 2011 10:57 AM |
| the fastest 2.3? | 87fourbanger | 2.3 Mustangs | 18 | October 17th, 2010 12:08 AM |
| What's the fastest you've been? | Dansby | The Clubhouse | 60 | October 23rd, 2008 04:31 PM |
| who has the fastest v6 here ? | 96b.boy | The Clubhouse | 72 | February 27th, 2008 12:48 AM |
| Who's the fastest? | WilltheThrill | Modular Mustangs | 31 | April 13th, 2007 11:02 PM |
