Choppy idle, bucking at W.O.T, High STFT Help.
Old February 6th, 2012, 12:44 PM   #1
Damaso is on a distinguished road
Hi guys i have a 02GT and just installed a cold air intake, and a stack racing upper intake plenum. I also have slp lm1s welded in. After install i noticed a slightly choppy idle and bucking at W.O.T if i have it in 5th going up a hill. I also checked data in a scan tool and it said my short term fuel trim was 23% at idle, and 10% at 2k rpm. i was thinking it could be the IAC or vacuum line, but i wanted some input. Thanks
1998 GT 5spd- Full pi swap, Fenderwell CAI,UPR Catted X-Pipe, Mac FlowPath Cat-Back
1988 LX auto- Pypes violator cat-back, UPR X-Pipe, Shift Kit, 4.10 Gears, Pulleys, Suspension upgraded, CAI
1999 GT 5spd- CAI, Pypes violator cat-back
Old February 6th, 2012, 01:01 PM   #2
MM Official Sammich Maker
roosgt!'s Avatar
1999 mustang gt
n/a
roosgt! is just really niceroosgt! is just really niceroosgt! is just really niceroosgt! is just really niceroosgt! is just really nice
Make sure all vacuum lines are on the plenum front and back, and look them over to make sure one has not collapsed.
I had the same problem after my instal awhile back and couldn't figure it out because all the lines were plugged in.
So I checked it out while the car was idling and noticed a vacuum line was shot.
KASE Racing
72 Chevell 500hp
74 Comet 500+hp and spray
99 Mustang GT bolt on's and 93 tune
85 Notch 520ci BBF
Old February 6th, 2012, 01:08 PM   #3
Nitmare67 is a jewel in the roughNitmare67 is a jewel in the roughNitmare67 is a jewel in the rough
Vacuum leak some where. High STFT indicates unmetered air is getting inside the motor
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber
Old February 6th, 2012, 01:11 PM   #4
04MidnightGT's Avatar
12.9 @ 111.44
04MidnightGT will become famous soon enough04MidnightGT will become famous soon enough
Use some ether and spray around the intake, when the idle goes up your found the leak!
l Custom Hotside l TurboSmart l MHS l Hallman l On3 l BBK l Hellion l SCT l Flowmaster l Steeda l AEM l Tial l HPX l Hawk l Trickflow
Threads Similar to: Choppy idle, bucking at W.O.T, High STFT Help.
Very high idle GTGUY 99-04 17 July 27th, 2011 08:40 AM
'95 v6 with idle surge/bucking issues Cobraman1024 V6 Mustangs 3 November 11th, 2010 06:24 PM
high idle StckFox 5.0 Mustangs 1 September 29th, 2010 09:49 PM
rough idle...bucking...clutch? or fuel pump? graygoose 96-98 11 May 21st, 2010 01:12 PM
High Idle tlgrant 99-04 10 December 18th, 2006 10:37 AM
