2003 Mustang GT
How much timing with meth and stock motor?
Some of you probably know Im buying an AIS trunk mount kit. Ordering it Wednesday
Going to run probably boost juice which is 49% methanol and 51% water. Run 2 jets, one pre blower, one pre throttle body. Im switching from my terrible intercooler and 2.87 pulley to a CX 4 core and 3.12 pulley. That alone with the extra CFM and not spinning the blower as hard should free up some power. Not that I really care, but Id like to be around 390-395rwhp with that setup at 10-11psi. Without Meth. With meth I should be over 400rwhp easy. But how much timing can I run? I plan on having my tuner write me 3 tunes 1 - No meth 2 - Meth but stock timing which is 15* more so for daily driving wise 3 - Meth on with more aggressive timing for track days. What would be good and safe? About 19-20*? And what should my AFR be on meth? Around 11.3-11.4? Thanks guys
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
Any reason why your not using 100% methanol? It's not that expensive. You can get a 5 gallon drum for $50. You will get A LOT more power out of pure methanol.
2000 Mustang GT Built 4V Motor with Sullivan Single Plane Intake Custom 66MM BB TT kit Borla XR-1 Dumped before rear Moser built 9" Rear 35 spline WaveTrac Diff with 3.75s 35 spline Moser axles 14PT roll cage and minitubbed
2003 Mustang GT
I cant find anyone around here that sells meth. At all, sucks
here ya go buddy
![]() MASSACHUSETTS MALDEN MACHINE MALDEN, MA 781-322-3246 BOUCHER'S RACING ENGINES ROWLEY, MA 978-948-7343 CASELLA AUTOMOTIVE SAUGUS, MA 781-231-2224 RON'S AUTOMOTIVE SOUTHBRIDGE, MA 508-764-3542 REID'S AUTOMOTIVE WHITMAN, MA 781-857-2500
2001 Mustang GT
8.98 1/8
Shaun, just look for any of these people im sure they could help you out
![]() Lol i wish i could actually help you out, but i couldn't resist cause its Monday
![]() CHECK MEH GARAGE BAMA Performance Drag Team #9 |
2000 MUSTANG GT
i'm still self tuning my car, and right now i'm running 18* timing, but some of my friends are running up to like 22* or close to that. i'm conservative compared to their cars, but i'm also interested in where you're going with this, because i have a 3.12 pulley, and i you probably hate me because i didnt sell it to you. what was you're timing at with the 2.87?
I would expect to see 20 - 24 degrees. I would start with 18 and go from there.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
#8 | |||
2003 Mustang GT
Cool sounds good to me, thanks man! Fuck I wonder if I could hit the 420rwhp mark....I would honestly only use that for track days. Trying to keep this motor togeather for another year
#9 | |
![]() any reason why you dont want to run straight meth? you will get some sick power with M1 meth with less timing
2003 Mustang GT
Idk, think maybe it might be to much on the stock motor? I know its obviously safe, but itll still pick up xx amount of power. dont want xx to be to much
its definitely safe. Since you wont need to run as much timing, the chance of detonation is reduced. Plus meth has great cooling properties
![]() On my pump gas setup without meth and 22psi the car made 846hp. same tune with meth and a little more timing it made over 1000! so it really adds a lot.
2003 Mustang GT
Holy shit lol. Ill definitley consider it then. Thanks man
2000 MUSTANG GT
then i'm wondering what timing i should be around if i put the 3.12 pulley on? any suggestions? currently running 3.6 pulley at 18*
i would imagine you would be able to stay at the same timing and make more power.
#15 | |
2003 Mustang GT
I would imagine 18* is a pretty damn safe conservative number for methanol.
no idea about the timing, but do you already have a meth kit? my buddies got an ais kit for sale
![]() '00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come. '95 GT, 347, tko, etc-11.8@116-sold. ![]() WTT-my mildly built 4r70 for t56/tko. |
2003 Mustang GT
Nah Id rather order it new. For the extra $100-150 its worth just buying new. Thanks though
00 Mustang GT Vert/88 5.0
Shaun that 3.12 is gona put you somewhere in the 15-16 PSI range with the 4 core. Im running a 2.9 and make 20-21 psi with the 4 core at around 6400 RPM.
![]() Proud Iraq and Afghanistan War veteran Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
2003 Mustang GT
Not with the S trim. And Si trim most definitley. Lots of people get around 9psi with the 4 core, a powerpipe and 3.33 pulley. Im not running a powerpipe, so I should be around 10-11psi
#20 | |
I think you should safely be able to run 19*. You can safely run 17* with one form of cooling so with two forms 19* shouldn't be a problem.
![]() 2003 DSG Mustang GT 5spd Full Bolt On's, Suspension, Built Rear, V1 S N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60' Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60' Intercooled: 362/370 |
Threads Similar to: How much timing with meth and stock motor?
| window motor timing | davidstivers09 | V6 Mustangs | 0 | December 23rd, 2010 03:39 PM |
| Stock timing at WOT | KevinJ99GT | 99-04 | 9 | December 22nd, 2010 06:30 AM |
| exploded views of stock 5.0 motor front of motor | White 89 | 5.0 Mustangs | 9 | October 15th, 2010 05:58 PM |
| Stock timing | F8L GT | 99-04 | 27 | March 10th, 2010 12:16 PM |
| How much boost can you put on a stock 4.6 v8 motor with out mesing up your motor? | Jonathan | General Tech | 3 | January 2nd, 2008 09:34 PM |
