I like boobs!!!
2000 GT convertible
dunno
4 cylinder V8... WTF???
So I'm here thinking my car is running like complete poo poo ca ca because I haven't gotten the tune right yet, but when we hooked it up to a scanner this weekend we found the entire right bank is dead!!!
So, here's what my thoughts are. The cam timing could be all dicked up on the passenger side, or there is an electrical gremlin. I'm not ruling out cam timing because everyone can make mistakes, but when I did it I could swear it was spot on. I used a degree wheel and a dial indicator and set the cam to 110 degree ICL. I haven't gotten a chance to run a compression check on it yet (that will tell for sure if there is a cam issue), but if it's an electrical gremlin, what could it be? A penny for your thoughts...
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
eating 1 ricer at a time
2002 mustang GT
not sure only ran on the streets so far!
![]() ![]() ![]() iTrader: 3 reviews
I'm more expensive than that ....
J.k I wish u luck Sent from my Autoguide iPhone app
Power in the hands of a few ![]() Buy your coffee from 02gt89 I guarantee better than starbucks click here |
well damb.
MM's king of Neon's
404 - car not found
17.81@87
As in it's not firing at all on that side? Even if your cam timing is effed, you should get some firing.
Have you checked the obvious things such as fuel and spark? I know all the COP's come to a single splice in the harness. If that got damaged you could have a whole set of misfires. Plus if you pull the valve cover it shouldn't be hard to tell if the cam timing is in the right neighborhood. Just throw your dial on the balancer and put a dowel down the bore and see when the valves are just about at max lift.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
2003 Mach 1
complete poop like wont stay running? When my 98 threw the cam gear off it (one cam not spinning) the car wouldn't stay running unless WOT, and even then only ran about 1200 RPMs.
Scanner said rank bank lean? or cyls 1-4 misfire? or what? Electrical could be cops, Injectors, easy to listen for. Or maybe upstream O2 for that bank is bad and tryin to compensate.
2003 Azure Blue Mach 1 - KB, Suspension, Bolt-ons. 497hp, 460tq. |
I like boobs!!!
2000 GT convertible
dunno
The scanner showed cylinders 1-4 misfiring. It's getting nothing from those 4. I would like to find where the COP's splice together in the harness. I'm not saying that that is definitely it, but I just don't feel like I messed up the cam timing.
When I tried to drive it you could tell it was loading up on fuel in the right bank and popping out the exhaust, just running like shit.
I would start by actually verifying spark, not hard to do. Go from there.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
I like boobs!!!
2000 GT convertible
dunno
I will be all of the testing on it starting Friday. I'm hoping that I don't go insane trying to find the problem
Stop freaking out. Just go through 1 step at a time. Verify you have spark, then move to fuel. Check the simple stuff first. You had the motor out theres a good chance something got unplugged or you forgot something. You'll figure it out.
2002 mustang gt
![]() iTrader: 1 reviews
Check your fuel pressure in the fuel rail, my first guess, I know gm's commonly misfire on one whole bank do to bad fuel rails...
Rock stock
I like boobs!!!
2000 GT convertible
dunno
It's definitely not a fuel rail issue. I am using the stock fuel rails. The pressure is the same in both rails. I'm thinking it's going to be a spark failure. Or should I say, I'm hoping it's a spark issue, I really don't want to go through re-degreeing the cam, but I will if I have to. Oh well, if it's not one thing it's another right? After I get a chance to diagnose it I'll post my findings. In the mean time any input/suggestions is/are appreciated.
Priest of the Car Gods
^^^ This. Occam's razor is your friend. Make a list, and put the simple/cheap/easy stuff up top. Nothing worse than tearing into something to find out when you put it back together that it was a fuse all along.
#13 | ||
I like boobs!!!
2000 GT convertible
dunno
Rev.. What is Occam's razor? Anyone know where in the harness the right bank COP's wires meet up? Edit: I just looked up Occam's razor. I like it!
1999 Mustang TermiGT
They meet near the firewall, near where the transmission harness meets the engine harness. Call me if that didn't help, I'll talk you through it.
Mods 545 RWHP/580 RWTQ on a Mustang Dyno Delta Force Tuned by Team Pure Insanity Racing |
I like boobs!!!
2000 GT convertible
dunno
Much appreciated. Like I said earlier, I will be going to work on it first thing Friday so hopefully I can find the issue. I bet it'll run a lot better once I get all cylinders firing.
1992 Mustang LX
not done yet
wait a second OP you said in an earlier post the cyl 1-4 arent firing, not sure about new Ford motors but in the old GMs they staggered the cylinder numbers...what I'm saying is odd numbers 1,3,5,7 would be right and even 2,4,6,8 are the left side if thats the case then the front cylinders arent firing
92 Mustang LX 5.0 5 spd convertable, with Eagle alloy rims, custom exhaust with headers and custom driveshaft, MSD 01 Ford Ranger MODS: way to much time and money involved in this |
Trying to remember, does the 2v have just one mark on the gear or two like the 3v? You didnt put that bank 180 out did you?
#18 | |
I like boobs!!!
2000 GT convertible
dunno
I used COMP adjustable cam gears. And I don't see how it could be 180 out since when I degreed it I set the ICL at 110. I guess anything is possible. I'm going to check the obvious first.
#19 | |
I like boobs!!!
2000 GT convertible
dunno
#20 | |
1992 Mustang LX
not done yet
Threads Similar to: 4 cylinder V8... WTF???
| cylinder 4 misfire and lodw compression in that cylinder.. helpppppp | $GTSTUD$ | 99-04 | 2 | June 1st, 2011 12:23 AM |
| which cylinder? | SadleUp | 99-04 | 9 | December 19th, 2010 03:11 PM |
| Mud In #4 Cylinder of the 302 V8 | Gregski | Mustang II | 2 | April 24th, 2010 03:09 AM |
| One Bad Ass 4 cylinder | TurboLX | The Clubhouse | 2 | November 30th, 2007 04:39 PM |
| Best mod I ever did for my six cylinder. | Cricket | The Clubhouse | 51 | May 16th, 2007 12:10 AM |
