o1 turbo gt 5.4 4v
Old February 7th, 2012, 08:22 AM   #1
turbo 5.4 is on a distinguished road
o1 turbo gt 5.4 4v
Have not posted in a while,seams like one problem after another since i started this build,i actually thought i would be tuned and at the track last aug.
List of mods-logan intake,04 cobra heads reworked with a three angle valve job,stock springs and cams,85lb. bosh injectors low imp. return fuel system,fore hat with two warlbaro 405 pumps,-8 feed and return lines,10 to 1 compression,all forged and arp,with windage tray.
Power adder is a 80mm borg warner with forward facing stock headers with two and ahalf inch feed pipes with a single 4 inch down no cats turned down before axels.Twin 38 tile waste gates,50ml tile blow off valve.
Trans- auto fb performance 4stb-e, pi converter, 4000stall with transbreak.We had it at the dino several times with a couple of different issues,trying to wrap up a fuel prob. right now.Should be back on the dino this week,i will keep everyone posted on the numbers.How do i post pics?
Old February 7th, 2012, 08:47 AM   #2
2003 Mach 1
glittle75 has a spectacular aura aboutglittle75 has a spectacular aura aboutglittle75 has a spectacular aura about
thing sounds like a monster. How much PSI you looking to run?
and maybe go make a newbie thread with this ifo and some pics!
Welcome.
2003 Azure Blue Mach 1 - KB, Suspension, Bolt-ons.
497hp, 460tq.
Old February 7th, 2012, 12:02 PM   #3
termi_GT's Avatar
12.41@114
termi_GT has a spectacular aura abouttermi_GT has a spectacular aura about
Lot of compression with a turbo set-up like that.
MM FOBRA CLUB CO-FOUNDER
Old February 7th, 2012, 12:06 PM   #4
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
Me Gusta... D: I would put turbo on my build but im gonna put it on my 5.6 Fox Tell us how that goes. Trying to learn this turbo stuff as much as possible.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
Old February 7th, 2012, 12:41 PM   #5
Willy Mo's Avatar
Willy Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really nice
Old February 7th, 2012, 05:43 PM   #6
Welcome.
20lbs.
Old February 7th, 2012, 05:45 PM   #7
e_85 daily and c16 sometimes on raceday.
Old February 7th, 2012, 05:50 PM   #8
i was new to it till i started this build.Before 5.4 2v with 200 shot,before that 4.6 d1 pro charger with a 150 shot,and before that 4.6 heads and cams 125 shot.This turbo build has been interesting and slow.
Old February 7th, 2012, 05:52 PM   #9
Originally Posted by Willy Mo View Post
I have a couple of pics down loaded from when i first started dont know how to post.
Old February 9th, 2012, 08:52 AM   #10
how do i load pics?
Old February 9th, 2012, 08:56 AM   #11
WhiteNoise's Avatar
1997 Mustang GT
WhiteNoise will become famous soon enough
Upload them to photobucket, and the link code is under the pic thumbnail on your album.
Mods: MAC o/r H, SCT tuner, CAI, short throw shifter, dash LED conversion Upcoming: Suspension build (Spring/Summer 2012)
Threads Similar to: o1 turbo gt 5.4 4v
Dyno results from new CEA 67mm Billet Turbo from Precision Turbo 499whp 552wtrq 13psi Turblow 99-04 18 November 9th, 2010 09:12 PM
Turbo timers and Boost Controllers? Turbo guys where you at? 95StangSVT General Tech 14 July 11th, 2008 07:01 AM
Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 Mellon Videos 10 December 30th, 2006 10:05 AM
Super Charger vs Turbo/Twin Turbo: Pros and Cons of each FireryDriver 2005 - 2010 9 September 17th, 2006 04:15 PM
