2002 mustang gt
14.069 @ 100
Things I need with new clutch.
So I'm gonna be fixing my trans and changing my clutch in the next couple weeks. I'm kind of unsure on a couple things.
I am getting a stock oem clutch, where can i buy one? Autozone or something? Where do I buy the TOB and PB??? Gonna get the clutch fork and pivot stud from ford. Also going to rent the pilot bearing removal tool. And take my flywheel somewhere to get resurfaced. Would i take it to an actual shop? And then of course fluid for the tranny. Is there anything I'm missing?
![]() Bassani O/R X Pipe, Borla Stingers, 70mm Accufab Throttle Body, K&N Intake, SCT XF3 Tuner, MGW STS GO BUCS!! |
2001 GT
You should be able to get essentially everything at autozone, advance, etc. For the flywheel I've heard certain car quests have a machine that can.
sent from my DINC2
1999 GT
Make sure to use Ford TOB and PB. You can order them from americanmuscle.com
99-04 Mustang Clutch Accessories - Free Shipping!
![]() 35th LE 99 GT |
2002 mustang gt
14.069 @ 100
^ So this
Ford Racing Mustang Roller Pilot Bearing (96-10 4.6L) M-7600-B - Free Shipping! and this Ford Racing Performance Mustang Throwout Bearing (79-04 V8) M-7548-A - Free Shipping!
1999 GT
You got it. Everything else you should be able to get at O'riellys/Autozone
2002 mustang gt
14.069 @ 100
Alright cool man thank you!
2003 ford mustang gt
13.9 stock
you should get a new rear main seal since your up in there already
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
03 GT
![]() ![]() iTrader: 4 reviews
clutch fork and pivot stud you can get from late model resto for about 55 dollars shipped
![]() Vortech v2 si-TiAl Q- CXRacing- still need MAF
Threads Similar to: Things I need with new clutch.
| clutch makes noise after replacing the clutch cable | BlkStallion89 | 5.0 Mustangs | 9 | December 6th, 2011 10:04 PM |
| new Clutch Ram 88951 vs Advance auto parts Perfection clutch | Paulnhbtx | 99-04 | 11 | October 3rd, 2011 01:53 AM |
| clutch pedal vibration and excessive clutch chatter | mscribellito | 99-04 | 13 | August 19th, 2010 04:59 PM |
| clutch replacement- replace whole clutch assembly or just clutch disc? | WilltheThrill | 4V / SVT | 12 | December 13th, 2008 12:18 AM |
| Getting My Clutch Quadrant, Adjustable Clutch Cable and | 97Cobra | 4V / SVT | 3 | May 2nd, 2007 02:33 PM |
