2001 Gt
DYNO? MAF?
I have an 01 GT and plan on getting dyno'd at the begining of next month. My first question is why do some dyno's have differnet numbers? My local shop told me to expect 10% less numbers than on a dyno jet.... He also told me that I should by a 90mm MAF before I go in. I will have LT's,or x, CAI, 75mm TB, and fox lake intake manifold, and UDP's.
Should I buy the MAF? |
12.41@114
That MAF seems to be overkill to me.
The reason dynos read diff. is because diff brands base their readings off other variables. Sounds to me that the place you are going has a Mustang dyno. Those #'s are based off a load that the Mustang dyno uses. Where as a Dynojet is not loaded. The power #'s on a loaded type dyno are generally more accurate then a Dynojet. You also have to consider elevation, air temps, how the dyno is actually set-up (you can adjust the load and such) and ect........... Regardless a dyno is still just a tool for tuning. If your tune is right and the car makes low #'s but runs awesome at the track, then who cares. Track #'s are the ones that count to me.
MM FOBRA CLUB CO-FOUNDER
2001 Gt
I understand that the number doesn't matter because it will run exactly the same regardless. Should I get a MAF or just run the stock one?
12.41@114
Stocker should be fine IMO.
12.73@111.36
I would use the stock MAF. It's good to around 360 rwhp.
Conventional wisdom says that Mustang Dynos read lower than Dynojets. In general that may be true but my car has been on both and the differences wasn't much. Actually one Dynojet read lower than the Mustang Dyno. Tempature, humidity, and altitude all affect horsepower. So uncorrected numbers can vary a lot. There are two standard correction programs that compensates for these environmental conditions: SAE and STD (also called STP). But they have different baselines. Because of this STD corrected numbers are typically 3-4% higher than SAE corrected numbers. The numbers in my signature are all from the same pull on a Dynojet. On that particular day the STD correction moved the numbers up while the SAE correction moved the numbers down.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
2001 Gt
Thanks man. I will just run my current MAF for now
Threads Similar to: DYNO? MAF?
| Dyno Video/Dyno Graph | RetroGT2006 | 2005 - 2010 | 12 | August 12th, 2010 03:45 AM |
| Recent Dyno Numbers (Mustang Dyno) | SKRMNGT | 99-04 | 13 | February 11th, 2010 12:36 PM |
| Dyno Tune at Dyno Tuned Performance | CW5billwade | 99-04 | 18 | March 20th, 2009 01:48 PM |
| Jan 19th Ft Myers - VMP Mobile Dyno - show, dyno runs and tuning by appointment | Justin00Stang | Southeast | 0 | January 4th, 2008 07:26 PM |
| Mustang Dyno Global Dyno Day! | BadMoFo | Southeast | 1 | September 20th, 2006 04:09 PM |
