Need a piston stop
Old February 7th, 2012, 07:19 PM   #1
I like boobs!!!
NickPohlAandP's Avatar
2000 GT convertible
dunno
NickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of light
Need a piston stop
I have a degree wheel and dial indicator, but I need a piston stop. Does anyone have a link to where I can get one and have it at my door by Friday? Many thanks for the help.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!!
My Garage--->http://www.moddedmustangs.com/forums...-member-46919/
Old February 7th, 2012, 07:42 PM   #2
gdl
99 Cobra, 03 Mach1, 07 CS
gdl has a spectacular aura aboutgdl has a spectacular aura about
Summit has a number of them, I think we take a 14mm but you should try to verify that.
Piston Stops - SummitRacing.com
2007 Redfire California Special
http://i183.photobucket.com/albums/x...n/2007GTCS.jpg
2003 Dark Shadow Grey Mach 1
http://i183.photobucket.com/albums/x...born/Mach1.jpg
1999 Black Cobra Vert
Old February 7th, 2012, 09:09 PM   #3
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Don't get the run of the mill screw type ones. The shoulder bottoms out before they thread in.
I think this is the one I used:
Crane Cams 99412-1 - Crane Piston Stop Tools - Overview - SummitRacing.com
It was on my doorstep in 2 days, granted I'm closer to them.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old February 7th, 2012, 09:28 PM   #4
I like boobs!!!
2000 GT convertible
dunno
Ha! No you're not. Summit is just about 2-3 hours down I-16 from me here in Georgia. Thanks Wicked. So the plugs are a 14mm thread?
Old February 7th, 2012, 09:33 PM   #5
MM's king of Neon's
404 - car not found
17.81@87
Yessir, M14x1.25 if I'm not mistaken.
And I'm just used to getting their parts from the Ohio facility.
I can't seem to find the exact one that I used, but it was a Crane and didn't have the shoulder on it. I had gotten the general degreeing kit and that stock stop didn't work.
And keep in mind that the stop can come in handy for things like tightening your balancer bolt!
Old February 7th, 2012, 09:42 PM   #6
I like boobs!!!
2000 GT convertible
dunno
I just bought it. Usually when I order stuff from Summit I will get it within a day or two from just regular ground shipping.
As far as using it to tighten my balancer bolt, I don't know about that. I don't think I'd be comfortable putting that kind of pressure on the piston in such a small spot, as well as the bearings without oil pressure. When I tightened my balancer bolt I just put the car in gear and pulled the e-brake.
Old February 7th, 2012, 09:47 PM   #7
MM's king of Neon's
404 - car not found
17.81@87
Still less pressure than BMEP (brake mean effective pressure) at rated power.
And not all of us have the luxury of doing things like installing with the engine already in the car and hooked up. Or power, heat, or light.
Old February 7th, 2012, 10:02 PM   #8
I like boobs!!!
2000 GT convertible
dunno
...And not all of us have the luxury of doing things like installing with the engine already in the car and hooked up. Or power, heat, or light.
My bad. I will go jump in a pond and roll in the dirt LOL
Threads Similar to: Need a piston stop
Is finding a piston stop really this hard? Bullitt5566 99-04 1 March 18th, 2011 01:05 AM
What piston stop? LaserRed97GT 96-98 3 January 26th, 2010 01:49 PM
piston stop Who makes one for the 3v? chad05gt 2005 - 2010 9 August 28th, 2008 09:53 AM
piston tdc stop ajm 99-04 0 July 14th, 2008 07:56 PM
Piston Stop 68 dlxcoupe 96-98 6 March 26th, 2008 05:17 PM
