Mysterious underhood squeal- ideas?
Old February 8th, 2012, 12:01 PM   #1
Chitty Chitty Bang Bang
TheOdessa's Avatar
2001 Mustang GT
TheOdessa has a spectacular aura aboutTheOdessa has a spectacular aura about
I am getting a loud squealing noise from the engine bay. I have a feeling it's the alternator, but I cannot pinpoint it as it seems louder when I put my ear close to the first two injectors toward the front of the car on the passenger side. Don't know if this is because the alternator sound is bouncing off the metal of the intake?
-Can I test the alternator by removing the belt and running the car? I am afraid if I remove the belt it might cause the engine to overheat. I guess I can always take the alternator to get bench tested
-Could the possibility be there that a failing injector squeals loudly?
-Anything internal such as a piston with a bad ring or not getting oil cause a squeal? I'm not sure why it'd happen so suddently.
76k on the motor
mods in signature
Belt looks new- new cracks or tears. Has Carquest stampings on it.
Alternator looks new, but it has a remanned sticker on it from Carquest so it's an aftermarket unit.
2001 Mustang GT 5-Speed
http://img265.imageshack.us/img265/4601/bulletss.jpg
God Created Man, but Sam Colt Made Them Equal
Old February 8th, 2012, 12:04 PM   #2
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Yes, pull the belt and start the engine. Don't let it run long and you won't have to worry about it overheating. It could be the alternator bearings, but more often it's a tensioner or idler pulley bearing that causes the squealing you've described.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old February 8th, 2012, 12:51 PM   #3
TheOdessa's Avatar
2001 Mustang GT
Thank you sir. I'm guessing spinning the idler or tensioner pully by hand will result in this squeal as it's so loud and there's no resistance behind it. If I find that is the root of the cause, should I not drive it til I fix it? I'm assuming the noise would be coming from failing ball bearings? I'm guessing simply buying a new pulley and replacing is all that's in store? Any special greasing of the pulley I should be aware of?
To take off the belt, should I wait for the car to cool to do it, or can I do it when the car's at operating temp. I want to remove the belt and test when I get home from work which is why I am asking.
Old February 8th, 2012, 01:00 PM   #4
Tang Stang's Avatar
Yes, the squealing noise is caused by failing bearings. If it's as loud/obnoxious as you've described, you should be able to determine which pulley is the culprit by feeling for excessive play in the bearings while wiggling the idler/tensioner pulleys with the belt removed. It is as simple as removing and reinstalling. You don't grease these.
When you get home from work, pull the belt, and start the engine. If the squealing noise is absent, you know that something in the FEAD is the source. If it is still present, you've just ruled out everything in the FEAD. You can do this test at operating temp, as you'll only have the engine running for thirty seconds at most.
Old February 8th, 2012, 01:32 PM   #5
TheOdessa's Avatar
2001 Mustang GT
Thanks man. I'll update tonight to keep people informed and maybe help someone else out with the problem.
When you say check the pulleys for excessive play, just wobble it? Would it squeal if I turn it by hand? Thanks for all the help by the way with my noob questions.
Old February 8th, 2012, 01:38 PM   #6
04MidnightGT's Avatar
12.9 @ 111.44
04MidnightGT will become famous soon enough04MidnightGT will become famous soon enough
Spray your pulleys one at a time while it's running with some wd40 and diagnose this!
l Custom Hotside l TurboSmart l MHS l Hallman l On3 l BBK l Hellion l SCT l Flowmaster l Steeda l AEM l Tial l HPX l Hawk l Trickflow
Old February 8th, 2012, 01:54 PM   #7
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
If the bearings are bad enough to be squealing like you say, they will wobble around when you check the pulley. I had a power steering pump going bad on a 4.6 that squealed like a pig, the pulley on that flopped all over when I took the belt off.
Do the Right Thing, Cook. ~Zip.
Old February 8th, 2012, 08:28 PM   #8
TheOdessa's Avatar
2001 Mustang GT
Well it ended up being this pulley
and it makes this noise when spun by hand
Video02082012201318 xvid - YouTube
What does this pulley do and why would it make this noise?
Old February 8th, 2012, 08:43 PM   #9
Tang Stang's Avatar
That would be the water pump. The water pump bearings are shot, and it needs to be replaced. How does the coolant look?
Old February 8th, 2012, 08:49 PM   #10
TheOdessa's Avatar
2001 Mustang GT
Damn damn damn
I'll take a look. Am I supposed to notice anything? Last I checked it was green. Could this failing water pump be the reason I smell a burning smell at times as I drive?
Old February 8th, 2012, 09:03 PM   #11
TheOdessa's Avatar
2001 Mustang GT
I have the early 2001 model mustang. What water pump do I use???
Old February 8th, 2012, 09:04 PM   #12
Tang Stang's Avatar
Green = good. Muddy brown = bad.
If it's a sweet burning smell, yes, it could very well be related.
You'll need the 96-mid '01 water pump if it's an early '01.
Old February 8th, 2012, 09:07 PM   #13
TheOdessa's Avatar
2001 Mustang GT
but do you know if it's 65mm or 87mm?
EDIT- Found it's 87MM. You da man Tang Stang!!!! Thanks so much!!!
Threads Similar to: Mysterious underhood squeal- ideas?
Underhood Airbrushing Ideas Wanted... Torched03Mach Pictures 0 September 19th, 2011 05:04 PM
Mysterious knock 99GT4.6HO 99-04 19 December 13th, 2010 02:40 PM
mysterious oil leak need help mustangracer2g 96-98 16 November 15th, 2010 01:44 AM
You know when you get the mysterious dent? XXGREGXX The Clubhouse 5 October 13th, 2010 10:31 PM
Help with mysterious noise? xXFalcoXx 99-04 6 December 30th, 2008 07:50 PM
