check engine light, i need some help
Old February 8th, 2012, 06:01 PM   #1
Bone Stock GT
1999 Black GT 5 speed
Black99GT is on a distinguished road
Send a message via AIM to Black99GT
ok since i am new to the new edge mustangs, i thought my cel might have been from fixing my exhaust leak that was leaking for who knows hong long before i bought the car, well on my way home from work i stopped at advance so they could scan it and tell me whats wrong, i have a hesitation under load that comes and goes. the scanned came up with 2 codes, a P0455 evap light leak detected and a P0442 gross leak detected no flow. what does this mean? and could it be my hesitation problem? i did notice last weekend i filled the tank for the first time and it leaked about a cup of gas overnight where i parked it. when i have 3/4 of a tank i get a real strong gas smell from the rear when i come back from a drive and shut the car off. my lincoln has an evap tray under the trunk and they are notorious for having problems. does anyone know what i should look for or has anyone had these same codes and fixed them? if so what did you have to do. i appreciate any help.
Old February 8th, 2012, 06:05 PM   #2
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
Here are the possible causes and diagnosis tips for P0455, and same for P0442...
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Old February 8th, 2012, 07:09 PM   #3
2002 mustang gt
Mystang 02GT is on a distinguished road
probably the fill neck,those hoses go bad on mustangs all the time.
Old February 8th, 2012, 09:21 PM   #4
Bone Stock GT
thats what i am thinking too because like i said last weekend when i filled it, it was running down the plastic tank shield from the pass side of the tank, and dripping off toward the back right corner of the tank near the pass side tail pipe. i guess i have to get under it to see whats going on. when its on my buddies lift getting the diff rebuilt and gears installed this weekend i will check out the tank, the evap tray and the hoses. do you think this would be causing the stuttering under load? i just put brand new plugs in it too. i want to put 8 new coils on it but they dont give those things away!!
Old February 8th, 2012, 09:40 PM   #5
'00 gt, '95 gt, '83 lx
11.85@116
bottled2v is a jewel in the roughbottled2v is a jewel in the roughbottled2v is a jewel in the rough
Send a message via AIM to bottled2v
an evap leak will not cause any stuttering issues. while it's on the hoist throw a new fuel filter on it.
the gaskets where the fuel filler tube go into the tank have had issues leaking, mine was leaking on my car when i bought it. those things are expensive too, you're looking at 30-40 for a ford one. luckily i get parts at cost so it only cost me 12 bucks haha.
'00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come.
'95 GT, 347, tko, etc-11.8@116-sold.
WTT-my mildly built 4r70 for t56/tko.
Old February 8th, 2012, 11:34 PM   #6
Bone Stock GT
I'll go under there with my cigarette lighter and see what's going on!
Old February 8th, 2012, 11:44 PM   #7
bulloch27's Avatar
2003 Mustang Fauxbra
N/T @ Fast
bulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the rough
That's a fine idea. Keep us posted on how that works out for you lol.
All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now?
03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold
Old February 8th, 2012, 11:49 PM   #8
cliffyk's Avatar
That'll work--do you want flowers or donations to a favourite charity?
-cliff knight-
My Mustang
Old February 8th, 2012, 11:58 PM   #9
bulloch27's Avatar
N/T @ Fast
Ima send mine to a burn center somewhere.
Threads Similar to: check engine light, i need some help
check engine light jman214 99-04 1 September 2nd, 2011 10:47 PM
check engine light bigboy05 99-04 8 March 29th, 2011 09:39 PM
Check Engine Light 94blakonblak 94-95 20 May 21st, 2009 11:03 PM
check engine light help!! rewadferger 96-98 7 May 18th, 2009 04:49 PM
Check engine light soccerboy08 V6 Mustangs 6 February 5th, 2008 01:03 PM
